# Hue Motion sensor no continuous light
**URL:** <https://community.homey.app/t/hue-motion-sensor-no-continuous-light/58414>\
**Tags:** flow, homey-pro\
**Created:** [January 14, 2022, 10:05am UTC](https://community.homey.app/t/hue-motion-sensor-no-continuous-light/58414 "2022-01-14T10:05:17Z")\
**Post date:** [January 14, 2022, 10:29am UTC](https://community.homey.app/t/hue-motion-sensor-no-continuous-light/58414/2 "2022-01-14T10:29:00Z")
Hi and welcome to the Homey community,
There are already multiple tutorials available.
From easy light control flows
> [@\[Simple\] Lights turning on/off based on motion](https://community.homey.app/t/simple-lights-turning-on-off-based-on-motion/10889):
> Simple flow for turning lights on and off based on motion What to use Timer app. In this case i used [the Countdown app](https://apps.athom.com/app/nl.bevlogenheid.countdown) Motion sensor. Used a Neo Coolcam pir v1 in this case. A light to switch on and off. Used a Fibaro Dimmer2 in this case to turn a “dumb bulb”. Start making the timer We click more/apps/Countdown. Then we click configure app. Here we make the timer. Choose a name for your timer. In this case i used “Badkamer” Click “Add timer” Start making the flows In this case i used…
> [@\[Tutorial\] Simple movement-triggered automatic light with zone activity cards (just 2 flows!)](https://community.homey.app/t/tutorial-simple-movement-triggered-automatic-light-with-zone-activity-cards-just-2-flows/39651):
> Hi everyone, It’s time to share back what I learned here. I have -in the past- tried several strategies to use lights that automatically trigger when movement is detected. Also, a lot has been written about this topic, for example: [Tutorial - Advanced automatic light control with flows](https://community.homey.app/t/tutorial-advanced-automatic-light-control-with-flows/21877)[[Simple] Lights turning on/off based on motion - #33 by EvR](https://community.homey.app/t/simple-lights-turning-on-off-based-on-motion/10889/33) and many more. All of these either use the CountDown App -or- the Timer App This allows for a lot of flexibility. But it can be tricky to config…
up to advanced light control flows:
> [@Tutorial - Advanced automatic light control with flows](https://community.homey.app/t/tutorial-advanced-automatic-light-control-with-flows/21877):
> Hi guys, I thought it was finally time to share my flows that I use to automatically control my lights. The setup I have is a bit more advanced than the suggestions I have seen on this forum, which is the reason for this tutorial. Some features of my setup: Automatically turn on and off lights based on motion (doh!) Only turn lights on when it’s dark Configuration of various scenes (e.g. Normal scene, Movie scene, Dinner scene, Romantic scene etc) Memory ability that will remember the brightn…
I guess you will find a solution for your requirements. If not, just ask.
_[View the full topic](https://community.homey.app/t/hue-motion-sensor-no-continuous-light/58414)._
