# How to set up IKEA tradfri gateway app?
**URL:** <https://community.homey.app/t/how-to-set-up-ikea-tradfri-gateway-app/12134>\
**Category:** Questions & Help\
**Tags:** app\
**Created:** [April 21, 2019, 6:17pm UTC](https://community.homey.app/t/how-to-set-up-ikea-tradfri-gateway-app/12134 "2019-04-21T18:17:01Z")\
**Posts on this page:** 6\
**Page:** 4
<div class="post-metadata">
**Author:** ![robertklep](https://sea1.discourse-cdn.com/flex025/user_avatar/community.homey.app/robertklep/32/160628_2.png) [@robertklep](https://community.homey.app/u/robertklep)\
**Post date:** [December 21, 2020, 6:20am UTC](https://community.homey.app/t/how-to-set-up-ikea-tradfri-gateway-app/12134/72 "2020-12-21T06:20:09Z")
</div>
I don’t run v5 so can’t comment on it, but I don’t use Homey for Zigbee (or home automation) in general anyway 😬
My experience with the gateway (more than a year ago) was pretty good, although every few weeks or so it starting giving issues and I had to reboot it. After a reboot, it worked fine for a few weeks again.
Make sure that the gateway has a fixed IP address in your network. I don’t think you can configure that on the gateway itself so you have to do that in your home network’s router (give it a fixed IP address in the DHCP settings). Otherwise the IP address may change and the app can “lose” it.
**Author:** ![JohnHomey](https://sea1.discourse-cdn.com/flex025/user_avatar/community.homey.app/johnhomey/32/30870_2.png) [@JohnHomey](https://community.homey.app/u/JohnHomey)\
**Post date:** [December 21, 2020, 9:42am UTC](https://community.homey.app/t/how-to-set-up-ikea-tradfri-gateway-app/12134/73 "2020-12-21T09:42:40Z")
</div>
_“Fixed IP”_ , Good one. It doesn’t have now so I will arrange that. Hope that improve the stability between the ikea hub and the homey. But first need to figure out why the Ikea hub itself lost several bulbs. When I find something I’ll just add it here.
**Author:** ![Raymond](https://sea1.discourse-cdn.com/flex025/user_avatar/community.homey.app/raymond/32/10027_2.png) [@Raymond](https://community.homey.app/u/Raymond)\
**Post date:** [December 21, 2020, 11:45am UTC](https://community.homey.app/t/how-to-set-up-ikea-tradfri-gateway-app/12134/74 "2020-12-21T11:45:59Z")
</div>
I experience the loss of bulbs in the ikea app after a firmware update of the bulbs themselves. Disconnect and reconnect the bulbs from the power supply solves the problem for me.
**Post date:** [December 21, 2020, 3:13pm UTC](https://community.homey.app/t/how-to-set-up-ikea-tradfri-gateway-app/12134/75 "2020-12-21T15:13:28Z")
</div>
Thanks Raymond, that did the trick! I designed the technical installation of the house for “smart only”, so we don’t have any wired switches. That shows a downside now that it’s more difficult to disconnect/power off some of the bulbs. But turning off a group on the fuse box / tech closet? does the trick. I try to prevent to do that often because all other devices connected, but for this simple reset it’s worth it, thanks a lot! 😀
**Author:** ![janklamer](https://sea1.discourse-cdn.com/flex025/user_avatar/community.homey.app/janklamer/32/24666_2.png) [@janklamer](https://community.homey.app/u/janklamer)\
**Post date:** [October 13, 2021, 12:14pm UTC](https://community.homey.app/t/how-to-set-up-ikea-tradfri-gateway-app/12134/76 "2021-10-13T12:14:50Z")
</div>
going bananas here…
So I know the IP adress and although the little white box of IKEA does not reply on the command “nslookup” - my router somehow knew it’s hostname. (GW-#### where ### is the serialnumber).
system overview;
homey pro (early 2019) running on version 7.1.4
Android phone app version 6.9.2.823
TP-link Archer C3200 router/switch
homey connected through wifi (should have ethernet too IMHO)
IKEA tradfri gateway connected through ethernet cable
at first, trying to configure the “IKEA trädfri gateway” app by going to … more → apps – IKEA trädfri gateway → cconfigure app, I kept getting the “device not found” error.
then I did another route; in the android app i went to settings, below there is also “apps” - IKEA trädfri gateway - same screen and POP, I got an identity and a PSK key - and could save this.
then going to the screen “apparaten” I could add the one socket (with remote) I have working on the gateway. YAY! cost me over 2 hours, but yay!
alas… using the android app - it does not listen to any commands and does not show the correct status either. sometimes all that happens is in the top of my screen “timeout after 3000ms”
**Author:** ![Dag\_Engstrom](https://sea1.discourse-cdn.com/flex025/user_avatar/community.homey.app/dag_engstrom/32/13281_2.png) [@Dag\_Engstrom](https://community.homey.app/u/Dag_Engstrom)\
**Post date:** [March 10, 2023, 9:19pm UTC](https://community.homey.app/t/how-to-set-up-ikea-tradfri-gateway-app/12134/77 "2023-03-10T21:19:07Z")
</div>
I’m trying to setup the IKEA tråfri Gateway APP and when I presse the DISCOVER button in the Homey app setup I keep getting the Error: Missing implementation for api endpint “discover” It is not possible to continue. The IKEA Hub is setup and works nice from the IKEA app no problem, but I cannot get the Homey IKEA tråfri Gateway to connect. Please help. Anything more you need? All the apps and IOS are the latest versions.
Best Regards
Dag Engstrøm
Norway
[Previous page](https://community.homey.app/t/how-to-set-up-ikea-tradfri-gateway-app/12134.md?page=3)
