# How to see what happened last in homey? What triggered which device
**URL:** <https://community.homey.app/t/how-to-see-what-happened-last-in-homey-what-triggered-which-device/19918>\
**Created:** [October 29, 2019, 8:05pm UTC](https://community.homey.app/t/how-to-see-what-happened-last-in-homey-what-triggered-which-device/19918 "2019-10-29T20:05:08Z")\
**Showing post:** 7
**Post date:** [October 3, 2021, 7:39pm UTC](https://community.homey.app/t/how-to-see-what-happened-last-in-homey-what-triggered-which-device/19918/7 "2021-10-03T19:39:26Z")
> [@Edwin\_D](#):
> So this would suggest it wasn’t a flow,
As far as I have seen Same on Homey & Homey Bridge as on Homey Pro!
Dim to fe 10% from a Flow this is not recorded (only on-off is recorded there.)
If a Light is OFF, and you set Dim to fe 10% from a Flow this is not recorded, but the driver tells also it should turn ON the light. (Default behaviour for most drivers)
So for almost ALL standard Apps using ON /OFF and Dim capabilities:
- you see ON/OFF only with the name of the Flow if the ON/OFF card is used in the Flow.
- you see ON/OFF only with the name of USER if the ON/OFF BUTTON or QuickAction is used.
- Whenever you you set a Dim level from a Flow or as user from the GUI / mobile App and the Light was OFF you see the Driver name as the one turning the Device ON.
Let’s say A known feature as designed.
_[View the full topic](https://community.homey.app/t/how-to-see-what-happened-last-in-homey-what-triggered-which-device/19918)._
