# How to see if Hue devices are controlled using Matter?
**URL:** <https://community.homey.app/t/how-to-see-if-hue-devices-are-controlled-using-matter/89835>\
**Tags:** homey-pro, homey-pro-2023, matter, hue\
**Created:** [September 20, 2023, 7:51pm UTC](https://community.homey.app/t/how-to-see-if-hue-devices-are-controlled-using-matter/89835 "2023-09-20T19:51:35Z")\
**Showing post:** 29
**Author:** ![Rrrr](https://sea1.discourse-cdn.com/flex025/user_avatar/community.homey.app/rrrr/32/629_2.png) [@Rrrr](https://community.homey.app/u/Rrrr)\
**Post date:** [January 15, 2024, 8:40pm UTC](https://community.homey.app/t/how-to-see-if-hue-devices-are-controlled-using-matter/89835/29 "2024-01-15T20:40:08Z")
Here’s some steps: [Add Philips Hue devices using Matter, not working - #74 by Rrrr](https://community.homey.app/t/add-philips-hue-devices-using-matter-not-working/89818/74)
Going to matter won’t hurt but if you used hue devices in your flows then you’ll need to redo those.
Take a lot of screen shots or before you migrate, change the devices to virtual devices, groups, or advanced devices that will require less work afterwards. Or use zones instead of devices.
> [@Add Philips Hue devices using Matter, not working](https://community.homey.app/t/add-philips-hue-devices-using-matter-not-working/89818/74):
> Moving to Matter with 3x Philips Hue bridges using iPhone (the menu in the Hue bridge app for Android works different) and Home Assistant. I am preparing the move, but got lost in the many different articles. Philips bridges can do Matter and only require re-registering each Bridge to Homey after which all (or most) Philips bridge connected devices should show up. Steps for Hue bridges: Optional upgrade [HP2023 to 10.3.x](https://support.homey.app/hc/en-us/articles/9075551662108-Matter-Beta-for-Homey-Pro-Early-2023-) (experimental) that provides web enabled capability for the move. I used…
_[View the full topic](https://community.homey.app/t/how-to-see-if-hue-devices-are-controlled-using-matter/89835)._
