# How can I easily see the mesh network for Z-Wave and Zigbee to spot weak/broken connections?
**URL:** <https://community.homey.app/t/how-can-i-easily-see-the-mesh-network-for-z-wave-and-zigbee-to-spot-weak-broken-connections/3444>\
**Category:** Devices\
**Created:** [October 30, 2018, 9:55am UTC](https://community.homey.app/t/how-can-i-easily-see-the-mesh-network-for-z-wave-and-zigbee-to-spot-weak-broken-connections/3444 "2018-10-30T09:55:45Z")\
**Showing post:** 30
**Author:** ![JanPieter88](https://sea1.discourse-cdn.com/flex025/user_avatar/community.homey.app/janpieter88/32/87145_2.png) [@JanPieter88](https://community.homey.app/u/JanPieter88)\
**Post date:** [October 10, 2023, 7:10am UTC](https://community.homey.app/t/how-can-i-easily-see-the-mesh-network-for-z-wave-and-zigbee-to-spot-weak-broken-connections/3444/30 "2023-10-10T07:10:30Z")
> [@Domenico\_Etere](#):
> But in that case if I am not wrong I have to rebuild all my Zigbee network again…
> Since I have 18 Zigbee devices (17 endpoints and 1 repeater) I would avoid to do this because I will have to change a ton of flows again…
Yes, you have to rebuild.
But in my experience (limited because I only tried this once, and I have few Zigbee devices), I didn’t have to rebuild any flows. I could ‘repair’ the devices, which means I had to put them in pairing mode, hold them close to the Homey hub etc. Devices got repaired and worked fine in their old flows iirc.
I think this is because the devices don’t actually are removed from Homey, they simply are unreachable until you repair.
_[edit] I just read this about removing vs repairing 🤔_ :
> [@Aqara Zigbee sensors](https://community.homey.app/t/aqara-zigbee-sensors/91311/10):
> Actually it was very bad in my case…after I did maintenance (when Athom releases firmware stating they were fixing some pairing issues on migrated Homeys), it works quite well and without issues. Unfortunately I have asked both, TED and Athom, if they can confirm that pairing again without removal = maintenance is or is not required and they DID NOT COMMENT (even when asked repeatedly) - as I have positive results after I did it, I do believe it’s a must (not sure why Athom do not release any …
> I don’t explain WHY the developers made the choice to disable this feature…
Yes, annoying when useful features get removed without any explanation. I also would like to see how my Zigbee network is routed.
_[View the full topic](https://community.homey.app/t/how-can-i-easily-see-the-mesh-network-for-z-wave-and-zigbee-to-spot-weak-broken-connections/3444)._
