# How can I convert x10 powerline signals to x10 RF signals? \[solved\]
**URL:** https://community.homey.app/t/how-can-i-convert-x10-powerline-signals-to-x10-rf-signals-solved/7478
**Created:** [January 20, 2019, 11:38am UTC](https://community.homey.app/t/how-can-i-convert-x10-powerline-signals-to-x10-rf-signals-solved/7478 "2019-01-20T11:38:16Z")
**Posts on this page:** 1
**Showing post:** 8
### Author: ![FKey](https://sea1.discourse-cdn.com/flex025/user_avatar/community.homey.app/fkey/32/14793_2.png) [@FKey](https://community.homey.app/u/FKey)
#### Post date: [January 26, 2019, 8:26pm UTC](https://community.homey.app/t/how-can-i-convert-x10-powerline-signals-to-x10-rf-signals-solved/7478/8 "2019-01-26T20:26:40Z")
> [@Bart\_van\_Diem](#):
> When I try to add a card in the “ than section” I cannot select a X10 action because it is not listed. Is this a known issue with the current release of X10 app in homey 2.0?
The X10 app is not ready for homey 2.0 yet. See this post
> [@\[APP\]\[Pro\] X10 App](https://community.homey.app/t/x10-app/140):
> HomeyX10 This app receives and transmits X10 signals over the air (433Mhz) (European x10 standard) Makes Homey backward compatible with classic domotica , X10 functions 30 years now. What works: X10 OnOff device X10 MS13E and lookalikes sensors (light alarm , movement alarm in one sensor) X10 Dim works What doesn’t: All commands not yet implemented. The app shows all kind of referencing and extending possible in node.js 4.6.0 with Ecma6 , programming it was an excercise for Ecma6 and…
> Does it work with the old homey software?
Yes it does, see screenshot below. Under “Apps” the X10 app should be available. Its not there in V2.0
> Anyway hope it will be solved in the near future.
@nattelip is working on it, more info in the post that is linked above
Its working in Homey 1.x
 ![image](https://us1.discourse-cdn.com/flex025/uploads/athom/original/2X/b/bd019ea16dc66182e4d4248342c50d0b2836152c.jpeg)
But X10 is not in the Apps list under “actions” in the new app yet
 ![image](https://us1.discourse-cdn.com/flex025/uploads/athom/original/2X/f/ff514193d2de1c71e4b5ea2c302c233489d6d378.jpeg)
SUGGESTION: for a workaroud, create new X10 device and name it the house code and number you want to send. Now you can add the device in the “when” and switch it on or off. This will make homey sent the X10 RF code
_[View the full topic](https://community.homey.app/t/how-can-i-convert-x10-powerline-signals-to-x10-rf-signals-solved/7478)._
