Homey Pro Community App Requests
What is the brand:
Ariston
What is/are the device(s)/service for type:
Examples:
Heater remote controll
What kind of category/signal(s) would the app use:
Wifi
Is there an (public) API / documentation / manual(s) or known (other) implementations (like Blogs/Github etc)?
HA page
Github Page
Pypi library wich is based the previous project
Are you willing to loan or donate to a developer?
  • No
Extra information:
no other infos
What kind of device would you like to be added :
  • NIO cars
    ES8
    EL7
    ET5
    ET7
    more to come
What kind of category signal would the app use :
  • Cloud
Is there a (public) API / documentation or known other implementations (like Blogs/Github etc)
  • Unknown
Are you willing to loan or donate a device to a developer?
  • Unwilling to loan my car, but I can help develop the app.
  • Willing to donate.
NIO is expanding in Europe and we need an app to control our cars.
Atm there are 4 models: ES8, EL7,ET5 and ET7. Only ES8 runs on the “old” architecture.
Anyone want to have a go with it?
What is the brand:
Your brand name. Jaguar IPace
Electric Car
  • IP (Local/Cloud/WiFi);
  • Yes, donate money €/$/£
Extra information:
What is the brand:
HeishaMon, Panasonic Aquarea
  • Controlling circuit board for Panasonic Aquarea heat pump
https://gathering.tweakers.net/forum/list_messages/2102536
  • No, device fixed to the wall
  • Yes, money
What is the brand:
E net server from Gira or Jung
Complete lightplan for houses
No idea
Don’t think so
Link(s) to where can this be found, the more information, the better.
  • Yes, loan a device
  • Yes, donate a device
  • Yes, donate money €250.-
Extra information:
Example:
Has an app for itselves, but there’s only a connection with google home and alexa
Mod: To be removed, Community App is live since 2023-02-20
[APP][Pro] Ohmigo - Ohm On Wifi
What is the brand:
OHMIGO
Your brand name.
OHMIGO
OHMIGO.ohmonwifi = Adds resistance output that can be used to replace any type of resistive temperature sensor, i. RTD like Pt100, Pt1000, Ni1000, NTC etc… with excellent accuracy from 68ohm to 9Mohm. In many applications it allows a replacement of te outdoor temperature sensor with a simulated temperature which can be calculated by Weather Data or other AI algorithms.
The OHMIGO.ohmonwifi device makes integration to existing heatpumps or controllers easy and possible.
  • IP (Local WiFi);
Everyhing is available from www.ohmigo.io
  • Yes, donate a device and money €/$/£
What is the brand:
Fairynest
Light and other smart sensors
BT and WIFI
App: ‎FairyNest on the App Store
Web: https://fairynest.in/
What is the brand:
Woox
  • smart ambiant light
  • Smart bulb
  • smart garde spotlight
  • smart two-way garden socket
  • smart plug (4pack)
  • smart temperature and humidity sensor
  • smart wireless mini switch
  • smart light strip kit full color+white
Is there any manual or documentation /Github etc)?:
Not that I could find, it should do something with Tuya but it doesn’t turns out.
Made in China
Post address in Spain however.
  • Yes, loan a device, oy in the Netherlands.
  • donate money,
    No, not at the moment.
Extra information:
Tuya should work as an App between but does not.
A smart Zigbee gateway is available but I don’t get it to work with it.
What is the brand:
Zaptec see www.zaptec.com
Wallbox (EV charger)
Cloud API (“ZapCloud”)
Yes, API is fully documented see here:
https://api.zaptec.com/help/index.html
GitHub - custom-components/zaptec: zaptec charger custom component for home assistant (Home Assistant integration)
The Swiss reseller (novavolt.ch) & Zaptec offers support and assistance with questions.
  • Yes, I would grant access to my Zaptec Cloud. (Zaptec go in use)
  • Yes, I would assist with testing and other tasks.
  • Yes, I would negotiate with Novavolt for more test accounts if needed.
Donations:
  • Yes, I would support the development with 200 Euro @rh_rh
  • Yes, I would support the development with Euros @Magnus_P
Extra information:
The API is very extensive. My focus is on the following points:
Prio 1:*
Set Loadbalancing.
The configuration of the power per phase defines the maximum power output which is available for charging the electric car. This is an officially supported feature of the API.
This function allows to individually control the charging based on the available power from a PV system. It also allows to prevent load shedding when too many end users (heating, etc.) are in operation at the same time as charging at certain times.
  • Current status (car connected, charging, no car connected etc.)
  • Current charge (kW)
  • Charging power (kWh)
  • Start / Stop charging process
    etc.
Functionalities for authorization of loading processes (commercial) are out of scope.
If you have any further questions, please do not hesitate to contact me
I have once again cleaned up the topic again, and 26 apps have since been created:
Aqua Temp
Aseko
Asus WRT
Balboa Spa
Bold Smart Lock
Dresden Led Controller
Ebeco
Flipr
Google Services
Heatzy
Heltun
iSmartGate
Kaipule
Lixee Linky
Luxaflex Powerview
Meross
Miele@Home
MyEnergi
Nest Cam
Niko (Zigbee)
Renault Z.E.
Samsung SmartThings (ZigBee, Aeotec App)
SecuYou
Toshiba AC
Volkswagen WeConnect
Worx
Zehnder
However, the searchbar still sucks, as there were again 9 duplicates, though that is way better then last time (49 duplicates).
Also removed one request that is impossible with Homey directly, as Homey doesn’t support EnOcean without any other bridge inbetween:
Eltako
What is the brand:
No brand, enthusiast product created by PLab.
Wall switch with eink screen and integrated temperature/humidity sensor:
https://docs.home-buttons.com/
Local , MQTT
Guides are linked on the product page above.
Not currently, unfortunately.
Extra information:
This device was created for Home Assistant, but perhaps it can be made to work with Homey?
What is the brand:
Sagemcom (type diw7022)
Examples:
  • TV Decoder (Android TV)
  • Bluetooth (BLE)
[Link(s) to where can this be found, the more information, the better.]
  • No
Extra information:
Example:
I Could not find the right App.
@Caseda , this one is alive now.
Sungrow Inverter
Simple using the Sungrow WebAPI - directly connected to their server (iSolarCloud). The option to connect via Modbus is more complicated and needs advanced skills to connect.
There are a few implementations for Homebridge and Home Assistant using the API. There is also an GoLang Implementation to access the iSolarCloud. All implementations are simple.
No
What is the brand:
Gira Enet
Examples:
  • Bridge (Server) for Gira Enet
  • Light control
  • Light sensor
  • Multipurpose
  • Wall switches
  • Blinds control
  • etc.
Gira API
Enet Smart Home integration for Home Assistant
Node.js API
  • No
Extra information:
The Home Assistant integration works through HACS, but is very solid.
Currently using the Home Assistant app in Homey to route my commands though there, but ideally I like to have a native integration in Homey.
What is the brand:
Zonneplan one
Solar panel inverter
Cloud based
There is a home assistant integration that works really nice.
I am willing to test.
Extra information:
What is the brand:
LG Smart thinq sensors
Air Conditioner(for me the one i use!)
Air Purifier
Dehumidifier
Dishwasher
Dryer
Fan
Range
Refrigerator
Styler
Washer
Water Heater
Cloud based
I am willing to test for the aircoditioner.
Extra information:
What is the brand:
TTLock
Smart lock
Extra information:
The TTLock open platform provides Web API and App SDK for developers to create the TTLock smart lock based applications
What is the brand:
DRAZICE - image
OKHE SMART - Water Heater
  • Bluetooth (BLE)
Exists support via HA and ESP32 board…
  • Yes, donate money 20€ + testing, providing feedback
What is the brand:
Jinko Solar
Solar
local network or cloud ;
i dont think so
