What kind of device would you like to be added :
Brand , and id number(s) of device(s)
Salus OS600 - Window and door sensor
Salus SW600 - Window and door sensor (Newer version)
Salus SB600 - Button
Salus CSB600 - Protected button
Salus SPE600 - Smart plug
Salus SR600 - Smart relay
Salus TRV10RFM - Thermostat
Salus VS10WRF - Thermostat, wireless
Salus UGE600 - Universal Gateway
Salus KL08RF - Wiring centre for 8-zone underfloor heating
Salus RX10RF iT600 system receiver
What kind of category signal would the app use :
ZigBee
TCP/IP(?) - Through gateway
Is there a (public) API / documentation or known other implementations (like Blogs/Github etc)
Can’t seem to find anything unfortunately.
Are you willing to loan or donate a device to a developer?
I don’t own a device so can’t. But if there is enough interest for this I would be inclined to donate some of them.
Honeywell Tuxedo Touch
Zwave
Http
Wifi
[http://www.tuxedotouchtoolkit.com/documents/Tuxedo_API_01.pdf ]
It's possible to test the device
DoC
November 10, 2018, 9:43pm
#14
**What kind of device would you like to be added
Wintop, iTabletDim, It’s a wall Dimmer.
Z-wave
manufacturer’s website: http://www.wintop.com/iSwitch/Index/design2/
Yes
Jung Radio controlled devices operating with 433.42 MHz – blind controls and lights
System set up is a Jung Radio hand-held transmitter 48 KFH that could be used to memorize the signal for Homey
Also receiver for motor contol inserts JUNG Universal 232ME
433.42Mhz
Not available / Not yet found any
Forums say same system as Gyra devices
Yes I could
efurdal
November 29, 2018, 8:48pm
#19
Not possible, installed on my watersupply
Itchy
December 1, 2018, 12:00pm
#21
https://www.senic.com/en/nuimo-control
Nuimo Control
Bluetooth 4.0 (BLE)
Where can this be found?
https://blog.senic.com/posts/programming-for-the-nuimo-controller
https://github.com/getsenic
if it works and a donation is available, why not.
someone has tested it an stop working on it, but i don't know why. ->
https://forum.athom.com/discussion/1628/nuimo-bluetooth-le
livolo VL-C702SR and other remote switch livolo
I created a thread with thinking behind and received some community feedback here:
Intergas Incomfort LAN2RF
IP-Based Communication
https://www.filedropper.com/lan2rfgatewayhttpinterface ( Credits to a topic on Tweakers)
Depends on the price
Konnected Smart Alarm
Wifi ? SmartHub
Yes https://github.com/konnected-io/konnected-security
Unfortunately no
ELRO- Remote SA68R
ELRO- Movement detector SA68P
ELRO- Sirene SA 68IS
ELRO- Flits and sirene SA68G
ELRO- Contact SA68M
ELRO- Wallswitch HIS20M
ELRO- Smoke detecter SA68B
ELRO- Sirene outside SA68IS
ELRO- KeypadSA68C
ELRO- Curtain switxh HIS20IC
ELRO- Wall outlet HIS20PSF
ELRO- Switch HIS20IS
433 MHZ
868 MHZ
Found nothing
Yes
Gb1974
December 10, 2018, 9:40pm
#32
UTC Fire & Security, ATS Advanced ATSx500-IP series.
IP (Ethernet)
Not yet
Not donate, but testing on my device is possible. An app has not to be free, but can be payed by people who want to use it.
An app for this system will be interesting for many people. One of the most used certified alarmsystems in europe.
Worx Landroid Automowers
Worx Landoird Wifi models
Worx, WiFi connected models,
IP/Http
Can find the API, but on Worx homepage they mention that there is an open source code
**Are you willing to loan or donate a device to a developer? No, I have moved on now.
Xtasy
December 18, 2018, 12:42pm
#37
Paulmann Leuchten 50046 SmartHome Zigbee MaxLED Tunabl White Control Maximum 144 W 24 V DC Gear Stick Grey Plastic Phone 500.46
Paulmann Zigbee Dimmers are integrated into Philips Hue and are supposed to be working soon with Homekit
Donate
!MAX Thermostat and windows Sensor
WiFi over the Cube (this is the central unit)
Openhab https://www.openhab.org/addons/bindings/max/
I would pay 50€ for it. The devices are very cheap and good.
But i can not use my cube from my environment.
PmM
January 1, 2019, 5:51pm
#48
Lupus Electronics (https://www.lupus-electronics.de/en )
-LUPUSEC Door contact v2 - article nr. 12113
LUPUSEC PIR motion detector - v2 - article nr. 12116
LUPUSEC keypad v2 - article nr. 12106
Description:
This is a home alarm system containing numerous alarm devices, sensors and smarthome devices.
The most basic version includes an alarm panel (eg. version XT1 plus), a door contact and a PIR motion detector:
https://www.lupus-electronics.de/shop/en/Alarm-Smarthome/Centrals/LUPUSEC-XT1-Plus-Starter-Kit-p.html
https://www.lupus-electronics.de/shop/en/Alarm-Smarthome/Alarm-Sensors/LUPUSEC-Door-contact-V2-p.html
https://www.lupus-electronics.de/shop/en/Alarm-Smarthome/Alarm-Sensors/LUPUSEC-PIR-motion-detector-V2-p.html
Lots of optional extras are available such as keypads, tag readers, cameras etc, eg:
https://www.lupus-electronics.de/shop/en/Alarm-Smarthome/Control-Unit/LUPUSEC-Keypad-V2-p.html
The alarm panel support Zigbee (ZBS v2.9.2.6.1) for a number of devices. The door sensor, motion detector and keypad use 868,35 MHz but it is unclear what protocol they support. Technical specifications are available at the above links.
The only one I could find is an integration of Lupus electronics devices to Home Assistant:
and a library to communicate with a previous (old) version of the alarm panel:
Unfortunately I don’t have a spare sensor (all installed) but I am willing to donate to the developer and happily assist in testing.
Honeywell Galaxy Flex 3 (with ethernet module A083-00-02) alarm panel.
not that i’m aware of. but there are diffentent applications that are able to control the panel (GXRemoteControl, SelfMon VKP)
I’m willing to contribute to the project by means of testing/debugging and ultimately paying a donation the the developer.
I heave a AED for public use. I want to know when it is needed
There is a API but i dont know whats avalible…
Willing to test. I heave a industrial programming background
Tag Reader
Tag Reader 500
There is an existing BeNext app, but it has not been maintained for more than a year by the original developer and is currently not compatible with the new release 2.x Homey version. Is there a developer who would like to pick this up and bring this app back to live?
GitHub
Yes
Thanks,
Frank Bakermans
