# Homey Pro 2023, 3 Bridge satellites, Zigbee and overall capacity?
**URL:** <https://community.homey.app/t/homey-pro-2023-3-bridge-satellites-zigbee-and-overall-capacity/117894>\
**Tags:** zigbee, flow, homey-pro, homey-bridge\
**Created:** [October 11, 2024, 1:19pm UTC](https://community.homey.app/t/homey-pro-2023-3-bridge-satellites-zigbee-and-overall-capacity/117894 "2024-10-11T13:19:39Z")\
**Author:** ![Henk\_Renting](https://sea1.discourse-cdn.com/flex025/user_avatar/community.homey.app/henk_renting/32/87634_2.png) [@Henk\_Renting](https://community.homey.app/u/Henk_Renting)\
**Post date:** [October 11, 2024, 3:02pm UTC](https://community.homey.app/t/homey-pro-2023-3-bridge-satellites-zigbee-and-overall-capacity/117894/2 "2024-10-11T15:02:49Z")
Since you already have them:
You could consider keeping devices on your Hue Bridges.
You just have a lot of devices and Homey/Zigbee might not be able to handle them very well.
In [THIS](https://homey.app/en-gb/app/nl.philips.hue/Philips-Hue/) app, multiple bridges are supported.
They create have their own Zigbee network, but the devices can be added to Homey as well, so you can control them from one place.
Just make sure you have enough routers in each Zigbee network to keep a good coverage throughout the house and check Zigbee channels to keep them from interfering with each other (and your wifi, which could be the start of your problem as well).
There’s a lot of info in the Community here that handles interfering Zigbee/WiFi. Just search here for those terms.
This might be a good start as well:
> [@\[HOW TO\] Plan and setup your Zigbee network](https://community.homey.app/t/how-to-plan-and-setup-your-zigbee-network/94770):
> This post is concerning The order of adding Zigbee devices to your Homey Pro/Bridge (AKA “Coordinator” or “hub”). Know that there is a best approach to in which order you connect your devices. You have at least three major category of devices. Which to connect when, that’s what I will dive into in this article. What are the issues? So, cutting right to the chase: The most common issues you will run into with your zigbee devices, is either unreachable devices or you’ve added the maximum of devi…
_[View the full topic](https://community.homey.app/t/homey-pro-2023-3-bridge-satellites-zigbee-and-overall-capacity/117894)._
