# Homey.ink, an e-ink Homey dashboard
**URL:** <https://community.homey.app/t/homey-ink-an-e-ink-homey-dashboard/12367>\
**Category:** Apps\
**Tags:** app, official\
**Created:** [April 27, 2019, 9:04pm UTC](https://community.homey.app/t/homey-ink-an-e-ink-homey-dashboard/12367 "2019-04-27T21:04:48Z")\
**Post date:** [April 27, 2019, 9:05pm UTC](https://community.homey.app/t/homey-ink-an-e-ink-homey-dashboard/12367/2 "2019-04-27T21:05:11Z")
**[FAQ] about Homey.ink, an e-ink Homey dashboard**
- ~~ I found an small error in the original instructions, Start your local Server with serving the app folder:
 `serve -p 5000 <Pathe-to-your-local-copy\homey.ink\app` (or references don’t work…)~~
- ~~Then your local URL reference will look more like the online one, Remove the `app/index.html` from it, it will now be: (These two are reported to Athom, probably~~ **fixed** 🔜 Now:
`http://localhost:5000/?token=YOUR_TOKEN&theme=YOUR_THEME` .
- Both Kobo’s need a rotation, developing local in Chrome doesn’t, remove in the 11th line the 9 from the rotate(90deg) and you are done for local testing! replace it back before going to production 😉
`-webkit-transform: rotate( *9* 0deg) translateX(180px) translateY(180px);`
- Trying the page from your device it needs the IP of your developing computer! Where localhost always point back to the computer you work on, I replaced it with the IP Address in the URL to test it from the Kobo. `http:// **192.168.1.2** :5000/?token=YOUR_TOKEN&theme=YOUR_THEME` .
- Then probably it will not work as your good protected Computer blocks it in the firewall and/or Windows Defender. Open an Powershell as Administrator and past, `New-NetFirewallRule -DisplayName "Enable Serve Inbound Port 5000" -Direction Inbound -LocalPort 5000 -Protocol TCP -Action Allow -Program "C:\program files\nodejs\node.exe" -Profile Any` Now it should work (and saver than disabling the complete Firewall!)
- Kobo themes use a rotation to support landscape presentation on the browser that by itself does not support rotation. See the line with `-webkit-transform: rotate(90deg)` in the `/app/css/themes/[themename].css` file.
_[View the full topic](https://community.homey.app/t/homey-ink-an-e-ink-homey-dashboard/12367)._
