# Homey early 2023 - Einrichtung und restore
**URL:** <https://community.homey.app/t/homey-early-2023-einrichtung-und-restore/77539>\
**Category:** Geräte\
**Created:** [March 12, 2023, 5:41am UTC](https://community.homey.app/t/homey-early-2023-einrichtung-und-restore/77539 "2023-03-12T05:41:05Z")\
**Post date:** [March 12, 2023, 10:50am UTC](https://community.homey.app/t/homey-early-2023-einrichtung-und-restore/77539/2 "2023-03-12T10:50:31Z")
Weil bereits jetzt einige User hier im Forum und auf Slack um Hilfe schreien, hier einige grundlegende Punkte auf die Athom übrigens bereits in der Mail **👀 Read This First — Homey Pro Early Access** hingewiesen hat. Diese Support-Artikel sind übrigens alle auf der Seite [Homey Support](https://support.homey.app/hc/en-us) → [Homey Pro (early 2023)](https://support.homey.app/hc/en-us/categories/7262004404380-Homey-Pro-Early-2023-) → [General](https://support.homey.app/hc/en-us/sections/7262045353628-General) zu finden:
**Homey Pro — Early Access Status**
[https://homey.app/en-us/wiki/hp23-early-access/](https://homey.app/en-us/wiki/hp23-early-access/)
**Setting up Homey Pro (Early 2023)**
> **[Setting up Homey Pro (Early 2023)](https://support.homey.app/hc/en-us/articles/7262272408732-Setting-up-Homey-Pro-Early-2023)**
> Congratulations! You are the proud owner of a brand new Homey Pro (Early 2023). 🎉
> 1. Plug in the power adapter
> To install Homey Pro for the first time, simply plug in the power adapter and conne...
_💡 Compared to the previous generation Homey Pro, the Wi-Fi set-up is different. Homey Pro does not broadcast a Wi-Fi network (HomeySetup-XXXXXX) anymore, but the connection is made using Bluetooth._
**Setting up the Homey Pro Ethernet Adapter**
(Das kurze Kabel muss in das Netzteil, das lange in den Homey!)
> **[Setting up the Homey Pro Ethernet Adapter](https://support.homey.app/hc/en-us/articles/7262533910300-Setting-up-the-Homey-Pro-Ethernet-Adapter)**
> You can use the Homey Pro Ethernet Adapter together with Homey Pro (Early 2023) to add wired connectivity to Homey Pro. Here, we explain how to set this up.
> Plugging in
> The Homey Pro Ethernet Adap...
**Resetting Homey Pro (Early 2023) to Factory Settings**
> **[Resetting Homey Pro (Early 2023) to factory defaults](https://support.homey.app/hc/en-us/articles/7261843930396-Resetting-Homey-Pro-Early-2023-to-factory-defaults)**
> Resetting Homey Pro (Early 2023) to factory defaults will delete all stored data on Homey Pro, including Apps, Flows, Insights, Devices, and stored Wi-Fi credentials.
> To reset Homey Pro (Earl...
Bei einigen Usern hat die Migration, also das Einspielen eines Backups vom Homey Pro 2019 und älter, nicht auf Anhieb funktioniert. Durch Zurücksetzen des Homey Pro 2023 auf Werkseinstellung konnte das Problem behoben werden.
**Understanding Homey Pro (Early 2023)'s LED Ring**
> **[Understanding the LED Ring of Homey Pro (Early 2023)](https://support.homey.app/hc/en-us/articles/7257933460764-Understanding-the-LED-Ring-of-Homey-Pro-Early-2023)**
> Next to being stunningly beautiful, the LED Ring of Homey Pro (Early 2023) is also used to visualize what Homey Pro is doing.
> Spectrum — Homey Pro is working normally, and the screensaver is s...
**Setting up Satellite Mode**
> **[Setting up Satellite Mode for Homey Pro (Early 2023)](https://support.homey.app/hc/en-us/articles/7263667137052-Setting-up-Satellite-Mode-for-Homey-Pro-Early-2023)**
> Homey Pro (Early 2023) can connect to multiple Homey Bridges, strengthening your Zigbee and Z-Wave networks while letting you reach more 433 MHz, Infrared, and Bluetooth devices throughout your hom...
**Connecting Homey Pro (Early 2023) to a PC / Mac with USB**
> **[Connecting Homey Pro (Early 2023) to a PC or Mac with USB](https://support.homey.app/hc/en-us/articles/7263435817116-Connecting-Homey-Pro-Early-2023-to-a-PC-or-Mac-with-USB)**
> You can connect Homey Pro (Early 2023) to a PC or Mac to create a local backup, restore it, update the software, and perform a factory reset. Here, we walk you through how it works.
> 1. Unplug Home...
**Activating Setup Mode for Homey Pro (Early 2023)**
> **[Activating Setup Mode for Homey Pro (Early 2023)](https://support.homey.app/hc/en-us/articles/7263241090716-Activating-Setup-Mode-for-Homey-Pro-Early-2023)**
> Homey Pro (Early 2023)'s Setup Mode allows you to change the Wi-Fi Network, reset Homey Pro to Factory Settings, or restore a cloud backup.
> While Homey Pro is in Setup Mode, all other tasks are dis...
_[View the full topic](https://community.homey.app/t/homey-early-2023-einrichtung-und-restore/77539)._
