[Requests] Homey Pro Community App Requests
What kind of device would you like to be added :
Lupus Electronics (https://www.lupus-electronics.de/en)
-LUPUSEC Door contact v2 - article nr. 12113
  • LUPUSEC PIR motion detector - v2 - article nr. 12116
  • LUPUSEC keypad v2 - article nr. 12106
Description:
This is a home alarm system containing numerous alarm devices, sensors and smarthome devices.
The most basic version includes an alarm panel (eg. version XT1 plus), a door contact and a PIR motion detector:
https://www.lupus-electronics.de/shop/en/Alarm-Smarthome/Centrals/LUPUSEC-XT1-Plus-Starter-Kit-p.html
https://www.lupus-electronics.de/shop/en/Alarm-Smarthome/Alarm-Sensors/LUPUSEC-Door-contact-V2-p.html
https://www.lupus-electronics.de/shop/en/Alarm-Smarthome/Alarm-Sensors/LUPUSEC-PIR-motion-detector-V2-p.html
Lots of optional extras are available such as keypads, tag readers, cameras etc, eg:
https://www.lupus-electronics.de/shop/en/Alarm-Smarthome/Control-Unit/LUPUSEC-Keypad-V2-p.html
What kind of category signal would the app use :
The alarm panel support Zigbee (ZBS v2.9.2.6.1) for a number of devices. The door sensor, motion detector and keypad use 868,35 MHz but it is unclear what protocol they support. Technical specifications are available at the above links.
Is there a (public) API / documentation or known other implementations (like Blogs/Github etc)
The only one I could find is an integration of Lupus electronics devices to Home Assistant:
and a library to communicate with a previous (old) version of the alarm panel:
Are you willing to loan or donate a device to a developer?
Unfortunately I donā€™t have a spare sensor (all installed) but I am willing to donate to the developer and happily assist in testing.
  • Honeywell Galaxy Flex 3 (with ethernet module A083-00-02) alarm panel.
  • IP
  • not that iā€™m aware of. but there are diffentent applications that are able to control the panel (GXRemoteControl, SelfMon VKP)
  • Sorry not possible
Iā€™m willing to contribute to the project by means of testing/debugging and ultimately paying a donation the the developer.
  • Hartslag Nu app
  • I heave a AED for public use. I want to know when it is needed
  • There is a API but i dont know whats avalibleā€¦
  • Willing to test. I heave a industrial programming background
Tag Reader
  • Brand , and id number(s) of device(s)
    Tag Reader 500
  • Zwave,
There is an existing BeNext app, but it has not been maintained for more than a year by the original developer and is currently not compatible with the new release 2.x Homey version. Is there a developer who would like to pick this up and bring this app back to live?
  • Where can this be found?
    GitHub
Yes
Thanks,
Frank Bakermans
  • ELKO IHC
Also branded as:
  • Lauritz Knudsen IHC
  • Schneider IHC
Ethernet
HomeAssistant Github:
Python IHC SDK / Earlier version:
Canā€™t remove from house installation, but happy to test / debug.
ā€¢KPN settopbox ARRIS 2952
ā€¢IR / modulation frequency 56 kHz
ā€¢https://gist.github.com/proycon/d8f730bb47ff6d7eaa12
ā€¢https://github.com/athombv/nl.kpn.ir
ā€¢If really needed: Yes
https://microbot.is/push/
ā€œMake Dumb Devices Smartā€
Wi-Fi (Prota?)
No API docs found, manual is here:https://support.thenaran.com/microbot-push
Other specs:
https://support.thenaran.com/microbot-push/basics/set-webhooks
https://support.thenaran.com/microbot-push/works-with/control-microbot-push-with-ifttt
Preferably a donation from users that are interested would be the way to go.
Linak Remote Control TV lift
Modbreak: moved to this thread. By @Dijker
I have a TV lift with a Remote Control. Anybody an Idea To connect it to Homey?
  • Linak HB10RF, Remote Control for a TV lift
  • Transmitter signal based on 433 MHz
  • Not that Iā€™m aware off
  • Yes
  • LG SmartThinQ Smart Appliances (washers, dryers, vacuum cleaners, etc). I personally have a LG RC80U2AV3W Heat Pump Dryer, so that would of course have my preference.
  • LG Smart Home Platform
  • No.
Garage door controller
    Tailwind iQ3
WiFi/Bluetooth
I donā€™t think so, but there are skills for Amazon Alexa and Google Home
    N/A
No
Texecom Connect Link to Texecom Alarm Panels
    Texecom Connect
    Connect allows setting of the alarm, unsetting, panic alarm, sensor activation from PIRā€™s
WiFi/Ethernet connection to the local network.
IP connection.
There is an API available from Texecom if a NDA is signed.
Texecom website.
I canā€™t loan it as itā€™s all wired in, but more than willing to work with to test.
Continuing the discussion from Homey Community App Requests:
  • Philips HTB4150B (ā€œPhilips Soundstage Home Cinemaā€)
  • IR
  • TCP/IP?
    Using NMAP, I found an open port at 8080/tcp and responding to a simple GET-requests (Server: VS/1.0?).
I havenā€™t found any documentation specific to the device (either IR or TCP/IP).
  • Yes, if it helps, I can temporary loan the device.
  • If I have starting point, and probably some community help, I like to create my first app.
What Iā€™ve done myself
  1. I asked for device support from Athom.
    They suggested logging a request, using a Google Forms document (I did a while back, maybe the community is quicker).
  2. Somehow my Homey doesnā€™t like recording the IR signal from the remote and replay.
    Iā€™ve opened an issue at Athom.
    IR is working: Iā€™m using the Panasonic TV IR-app and the build-in Athom IR for controlling my TV/settopbox.
  3. I recorded the signal using the Homey Developers site
    But emulating the signal does nothing.
  4. Searched online for identifiers etc.
    Through Google I found the code ā€œ996510061354ā€ for a replacement remote, but can not find any technical details. I do not see any other identifying codes on or in the remote control.
    The remote control is visually similar to some HTBxxxx & HTSxxxx (Google Images)
  5. Found a LIRC-database, not sure if this is a good starting point
    • the db lists both remote IDā€™s and device IDā€™s, so itā€™s hard to find the matching remote
      • The BDP3000 looks somewhat similar
    • and, the format of the code is different of what I see in other IR apps
power-button signal
2700,837,495,834,492,395,508,379,491,839,931,405,933,837,489,397,494,392,933,397,492,832,939,399,502,828,491,394,497,390,936,395,496,390
491,65535
2655,867,468,863,476,410,468,418,462,868,905,425,920,855,462,424,467,420,907,424,467,863,904,440,448,880,457,419,470,419,919,412,457,429
462,83809,2665,878,458,864,461,426,465,422,459,872,911,419,907,869,458,433,459,422,914,415,476,857,905,423,466,864,462,425,466,421,905,425,466,421
460,65535
Wattle Home Control Outlet
    Wattle (originally made by HomeControl)
ZigBeeHA 2.4GHz
Donā€™t know
No, as I havenā€™t bought one yet
Asustor the same as the synologic surveillance center by Jorden Chamid
WiFi
I donā€™t know
No
  • Luxom Domotics: www.luxom.be
  • ASCII Code over TCP/IP (ideally bi-drectional / if you ā€œlistenā€ to the address, you can also capture the state of the different devices (lights (on / off / percentage if dimmed), temperature, ā€¦)
(fixed IP Address, PORT: 2301)
yes
http://luxom.be/uploads/ppfiles/28/LUXOM_ASCII_extended.pdf
This is the documentation on the TCP/IP interface:
http://www.luxom.be/uploads/ppfiles/32/LTF_E_DS65L.pdf
I canā€™t move my home to the Athom office. If it would help, I could contact the owner of the company.
  • Airplay
  • Airplay 2
  • Wifi?
  • Bluetooth?
No
Here are the details.
  • Zwave
  • Not yet available. Sent an email to the vendor.
  • Yes
Cololight by LifeSmart
LifeSmart
**What kind of category signal would the app use
Wifi
Not that I know ofā€¦
Yes, that would be possible
