# Homey and Tasker communnication
**URL:** <https://community.homey.app/t/homey-and-tasker-communnication/57721>\
**Created:** [January 3, 2022, 4:38pm UTC](https://community.homey.app/t/homey-and-tasker-communnication/57721 "2022-01-03T16:38:15Z")\
**Post date:** [January 3, 2022, 5:05pm UTC](https://community.homey.app/t/homey-and-tasker-communnication/57721/2 "2022-01-03T17:05:00Z")
I don’t use Tasker, but I used the search function of the forum. Maybe this answers your question:
> [@\[TUTORIAL\] Using Tasker / KLWP together with Homey](https://community.homey.app/t/tutorial-using-tasker-klwp-together-with-homey/674):
> What are these tutorials for? If you need to read this, then this tutorial is probably not for you. I’m going to assume you know your way around Tasker (Android Automation App) and / or KLWP (configurable live wallpaper) and you know how to create Profiles and Tasks within Tasker or how to edit your live wallpaper within KLWP. If so, with these tutorials you should get an idea on how to use Tasker in combination with the Homey API. Occassionaly I’ll be using some other tools as well, mostly from…
> [@\[How To\] Setup two-way communication between Homey and Android smartphone](https://community.homey.app/t/how-to-setup-two-way-communication-between-homey-and-android-smartphone/55510):
> Quite often I like to use my Android smartphone to directly start a Homey flow, operate a Homey device or to put data into Homey flows without using the Homey app. If you would like to do the same, then this tutorial is for you. What will be addressed in this tutorial: Install Tasker on your Android smartphone Install Join on your Android smartphone Find device ID and generate Join API key Create Join URL Configure Tasker and Join to react to a received message Setup the webhook in a Homey fl…
_[View the full topic](https://community.homey.app/t/homey-and-tasker-communnication/57721)._
