# Help with a flow to start heating on my car
**URL:** <https://community.homey.app/t/help-with-a-flow-to-start-heating-on-my-car/36149>\
**Created:** [October 18, 2020, 6:53pm UTC](https://community.homey.app/t/help-with-a-flow-to-start-heating-on-my-car/36149 "2020-10-18T18:53:24Z")\
**Post date:** [October 18, 2020, 7:41pm UTC](https://community.homey.app/t/help-with-a-flow-to-start-heating-on-my-car/36149/2 "2020-10-18T19:41:24Z")
Hi Christer,
A warm welcome to the Homey User and the community.
I suggest you read the following tutorials to understand how flows are build and how they work:
> [@Getting Started - Creating flows](https://community.homey.app/t/getting-started-creating-flows/20051):
> In this tutorial you will learn to: create simple flows, using ‘when’ and ‘then’ learn to use tags in flows learn to expand your flows with ‘and’ learn to add multiple ‘then’ and ‘and’ cards learn to ‘invert’ cards Adding ‘or’ and ‘else’ will be part of the next tutorial. First, I assume that you have a Homey (pro) installed, a few apps and devices set-up and ready to go and some basic knowledge the English language. Furthermore, I assume that you have Homey’s location enabled. There are ot…
> [@Getting Started - The 'or' and 'else' parts of a flow](https://community.homey.app/t/getting-started-the-or-and-else-parts-of-a-flow/20059):
> Hi again! I hope you all enjoyed the first tutorial. This tutorial continues where the first one left off. In this tutorial, you will learn: to use the ‘or’ card to use the ‘else’ card This tutorial is a bit shorter than the first. Let’s start with the same flow: Now, this flow makes me unhappy. As you might remember, Grumpy is watching her show. She doesn’t bother to greet me. And Homey doesn’t say anything, because this flow stops when it concludes that the chromecast is playing.…
Your mistake is the following:
The AND section checks if certain properties (states, values, etc.) are true or not. These can be single properties or groups. If you want to check more properties, they are added below the OR.
If the properties in the area AND are fulfilled (above OR and/or below OR) then the action is executed in the area THEN.
If the properties in the area AND are not fulfilled (above OR and/or below OR) then the action in the area THEN is executed which is below OR.
_[View the full topic](https://community.homey.app/t/help-with-a-flow-to-start-heating-on-my-car/36149)._
