# Google assistant (integrated) to start flow
**URL:** <https://community.homey.app/t/google-assistant-integrated-to-start-flow/21519>\
**Category:** Questions & Help\
**Created:** [November 29, 2019, 2:36pm UTC](https://community.homey.app/t/google-assistant-integrated-to-start-flow/21519 "2019-11-29T14:36:12Z")\
**Posts on this page:** 6\
**Page:** 1
<div class="post-metadata">
**Author:** ![J\_G](https://sea1.discourse-cdn.com/flex025/user_avatar/community.homey.app/j_g/32/16719_2.png) [@J\_G](https://community.homey.app/u/J_G)\
**Post date:** [November 29, 2019, 2:36pm UTC](https://community.homey.app/t/google-assistant-integrated-to-start-flow/21519/1 "2019-11-29T14:36:12Z")
</div>
Hi there,
I’ve searched the forum but haven’t really found an answer yet.
I have integrated Google assistant with Homey (including synchronisation) and I would like to be able to start a flow directly from Google home. E.g. saying: “hey Google, good night”. Then a flow should be activated turning off the lights and arming the alarm. The only response I would like from Google home is “sleep well” as a confirmation that it is activated.
I am so far that it works if I tell google to ask homey to _name flow_. However, I believe it should work directly now, without the ‘ask homey’ part in between?
Also, Google replies that it is getting Homey, but this feels unnatural and I don’t want that.
So should it work directly like I want, or do we still need the Homey text in between?
If possible, what do I forget?
Edit: I have also seen posts about using a virtual switch. This seems like a lot of extra administrative effort and Google seems to ‘know’ the flows. So perhaps that’s not necessary?
Thanks for the help.
**Author:** ![Oscar1](https://sea1.discourse-cdn.com/flex025/user_avatar/community.homey.app/oscar1/32/8845_2.png) [@Oscar1](https://community.homey.app/u/Oscar1)\
**Post date:** [November 29, 2019, 2:59pm UTC](https://community.homey.app/t/google-assistant-integrated-to-start-flow/21519/2 "2019-11-29T14:59:32Z")
</div>
You can only start ‘things’ in Google Home if these are known in GH. A flow is not known in GH so you can not start a flow from GH, unless you are using a VD to start the flow.
**Post date:** [November 29, 2019, 3:12pm UTC](https://community.homey.app/t/google-assistant-integrated-to-start-flow/21519/3 "2019-11-29T15:12:35Z")
</div>
Then that explains it. No way around the virtual devices then. Thanks. I hoped GH would know the flows as well.
**Author:** ![kirsi\_vuoti](https://sea1.discourse-cdn.com/flex025/user_avatar/community.homey.app/kirsi_vuoti/32/17092_2.png) [@kirsi\_vuoti](https://community.homey.app/u/kirsi_vuoti)\
**Post date:** [December 2, 2019, 9:43pm UTC](https://community.homey.app/t/google-assistant-integrated-to-start-flow/21519/4 "2019-12-02T21:43:39Z")
</div>
Make a homey flow card, and connect it to IFTTT via Google home.
And besides, speech on Google home eg Google TTS
       Flow
When This Flow is started
And
Then Turn off (your lights)
Turn on (your secuurity system)
Google TTS (good night J\_G)
**Author:** ![DvStarrenburg](https://sea1.discourse-cdn.com/flex025/user_avatar/community.homey.app/dvstarrenburg/32/17154_2.png) [@DvStarrenburg](https://community.homey.app/u/DvStarrenburg)\
**Post date:** [December 23, 2022, 7:14pm UTC](https://community.homey.app/t/google-assistant-integrated-to-start-flow/21519/5 "2022-12-23T19:14:15Z")
</div>
> [@Google Home "Ask for Alarm" works with new preview!](https://community.homey.app/t/google-home-ask-for-alarm-works-with-new-preview/74047):
> In the last couple of years, I’ve seen a lot of questions about a Flow that makes Google ask you what time a wake up alarm should be set. This is possible in de new Google Home app. Create a virtual Home Device, create a routine in Google Home and you’re all set!
**Author:** ![Dijker](https://avatars.discourse-cdn.com/v4/letter/d/b9bd4f/32.png) [@Dijker](https://community.homey.app/u/Dijker)\
**Post date:** [June 7, 2025, 5:15pm UTC](https://community.homey.app/t/google-assistant-integrated-to-start-flow/21519/6 "2025-06-07T17:15:17Z")
</div>
Archived on June 7, 2025, 5:15pm UTC
