# Fibaro Singel Switch 2, and setting auto off
**URL:** <https://community.homey.app/t/fibaro-singel-switch-2-and-setting-auto-off/25861>\
**Tags:** app\
**Created:** [February 13, 2020, 12:12pm UTC](https://community.homey.app/t/fibaro-singel-switch-2-and-setting-auto-off/25861 "2020-02-13T12:12:47Z")\
**Post date:** [February 13, 2020, 12:22pm UTC](https://community.homey.app/t/fibaro-singel-switch-2-and-setting-auto-off/25861/2 "2020-02-13T12:22:02Z")
Have a look at this post:
> [@Z-Wave Raw Data Format Dev Postal](https://community.homey.app/t/z-wave-raw-data-format-dev-postal/15543/5):
> You need much more “parameters” when sending an configuration parameter, raw data is for all possible z-wave commands, not just parameters (like the expert parameters) which is only 1 of the many possible command classes. Dest Node ID, Command Class, Command Class Function, Value(s). so you should also add the Command Class for CONFIGURATION Command class (112) and the SET Function (4) in your line: 30,112,4,14,1,1 30: Destination Node ID 112: CONFIGURATION Command Class 4: CONFIGURATION S…
_[View the full topic](https://community.homey.app/t/fibaro-singel-switch-2-and-setting-auto-off/25861)._
