# Everspring dimmer AD147 lamp does not work
**URL:** <https://community.homey.app/t/everspring-dimmer-ad147-lamp-does-not-work/47455>\
**Category:** Devices\
**Created:** [May 16, 2021, 9:55am UTC](https://community.homey.app/t/everspring-dimmer-ad147-lamp-does-not-work/47455 "2021-05-16T09:55:43Z")\
**Posts on this page:** 3\
**Page:** 1
<div class="post-metadata">
**Author:** ![Jan-vK](https://sea1.discourse-cdn.com/flex025/user_avatar/community.homey.app/jan-vk/32/18446_2.png) [@Jan-vK](https://community.homey.app/u/Jan-vK)\
**Post date:** [May 16, 2021, 9:55am UTC](https://community.homey.app/t/everspring-dimmer-ad147-lamp-does-not-work/47455/1 "2021-05-16T09:55:43Z")
</div>
I have a new everspring dimmer but it does not work 100% correct.
When it is activated in dimmed (70-80%) condition the lamp is not on, but the device is activated according Homey.
I use a 7 W LED lamp
The dimming on/off function is set off
Is a electronic issue?
**Author:** ![Edwin\_D](https://sea1.discourse-cdn.com/flex025/user_avatar/community.homey.app/edwin_d/32/136417_2.png) [@Edwin\_D](https://community.homey.app/u/Edwin_D)\
**Post date:** [May 16, 2021, 1:48pm UTC](https://community.homey.app/t/everspring-dimmer-ad147-lamp-does-not-work/47455/2 "2021-05-16T13:48:08Z")
</div>
7W is on the low side of the range it should be able to handle, might be too near the edge, in that case a bypass may help. But before you go that way:
Are you sure the led bulb is dimmable? Are yo able to dim it at all and is the range for dimming just really narrow, or is the bulb only on or off, nothing in between?
The dimmer does not really say much in the manual about the dimming technology. Some led bulbs are designed to exclusively work with leading edge dimming, others trailing edge. Might just be the led light is dimmable but not compatible with the dimmer technology.
**Post date:** [May 16, 2021, 2:16pm UTC](https://community.homey.app/t/everspring-dimmer-ad147-lamp-does-not-work/47455/3 "2021-05-16T14:16:29Z")
</div>
Thank you for your reply
Yes the led bulb is dimable, I used it with a KaKu dimmer before. It is an Ikea LED1522R6.
When the lamp is on I can dim the lamp without any problem and stable
