# Eglo Connect-z Remote 2.0 Wont Connect
**URL:** <https://community.homey.app/t/eglo-connect-z-remote-2-0-wont-connect/102800>\
**Category:** Devices\
**Tags:** zigbee, homey-pro\
**Created:** [January 31, 2024, 6:10am UTC](https://community.homey.app/t/eglo-connect-z-remote-2-0-wont-connect/102800 "2024-01-31T06:10:38Z")\
**Showing post:** 13
**Author:** ![Farside](https://sea1.discourse-cdn.com/flex025/user_avatar/community.homey.app/farside/32/124754_2.png) [@Farside](https://community.homey.app/u/Farside)\
**Post date:** [December 3, 2025, 4:47pm UTC](https://community.homey.app/t/eglo-connect-z-remote-2-0-wont-connect/102800/13 "2025-12-03T16:47:13Z")
Hi everyone. It took me some trial and error to pair up **Eglo’s Connect Remote 2.0 to Homey** , but here’s the process that got it working:
1. Install the smartphone app called **AwoX HomeControl** (don’t get confused, the old AwoX app won’t work, you need exactly this newer app version)
2. Start the **AwoX** app, set the remote in pairing mode with [on] + [blue] simultaneously for 3 seconds – it will blink with red light, pairing activated.
3. Connect it to the app, then run **Upgrade the firmware** (mandatory step, to make it work with Homey).
4. It’s important to **factory reset the remote** with [on] + [colored wheel] for 3 seconds, otherwise it won’t connect to Homey. Remote should blink many times with red LED again.
5. Remove device from **AwoX HomeControl** app.
Set Eglo Remote 2.0 into **pairing mode** by pressing [on] + [blue] simultaneously for 3 seconds
6. In **Homey’s Eglo app** press **add device** and choose _Remote 2.0_ - it should show up and pair up.
7. … profit! \<3
Unfortunately without those actions, the remote won’t connect, as it runs the old firmware and requires to be updated. It’s for good, anyway, as they had quite a few security fixes as well.
Hope this manual helps! Don’t forget to like this post, so it bubbles up in the search.
_[View the full topic](https://community.homey.app/t/eglo-connect-z-remote-2-0-wont-connect/102800)._
