# DIY circadian rhythm based lighting
**URL:** <https://community.homey.app/t/diy-circadian-rhythm-based-lighting/33348>\
**Category:** Developers\
**Tags:** app, homeyscript, flow\
**Created:** [August 7, 2020, 1:17pm UTC](https://community.homey.app/t/diy-circadian-rhythm-based-lighting/33348 "2020-08-07T13:17:53Z")\
**Showing post:** 45
**Post date:** [April 30, 2022, 9:38am UTC](https://community.homey.app/t/diy-circadian-rhythm-based-lighting/33348/45 "2022-04-30T09:38:03Z")
This is the entire updated script for Homey firmware v7.4.x, based on the script in post [#16](https://community.homey.app/t/diy-circadian-rhythm-based-lighting/33348/16), which I modified a little bit in comparison to the original script:
```auto
 * Adjust Color temperature and Brightness based on time of day
 * as if it were April 16th, a nice long spring day in southern Sweden
const VARIABLE_PREFIX = 'Circadian';
const MIN_BRIGHTNESS = 0.40;
const MAX_BRIGHTNESS = 0.75;
const MIN_TEMPERATURE = 0.3;
const MAX_TEMPERATURE = 0.8;
const sys = await Homey.system.getInfo();
// hack because sys date no longer returns local time, but rather UTC :(
const regex = /(\d\d):(\d\d):(\d\d)/;
const timeMatches = sys.dateHuman.match(regex)
const solarNoon = 0.546 // on April 16 is 13:06
// defaults
let temperature = MIN_TEMPERATURE; // Homey color temperature: 0 (coolest, midday) to 1 (warmest, sunset/sunrise)
let brightness = MIN_BRIGHTNESS; // [0-1]
// used standard normal distribution curve to derive equation [https://en.wikipedia.org/wiki/Normal_distribution#Standard_normal_distribution]
// equations adjusted for color temperature and brightness [https://codepen.io/suhajdab/pen/wvzpqdQ?editors=0010]
getTemperaturePoint = x => {
    const r = 0.20; // adjust curve width
    return Math.pow(Math.E, -0.3 * Math.pow((x - solarNoon) / r, 4));
getBrightnessPoint = x => {
    const r = 0.28; // adjust curve width
    return Math.min(1 * Math.pow(Math.E, -0.3 * Math.pow((x - solarNoon) / r, 8)), 1);
// round to 2 decimal places to avoid 'invalid token error' when reading in a flow
const roundDecimals = (num, places = 2) => {
    return Math.round(num * Math.pow(10, places)) / Math.pow(10, places);
const dayStart = new Date(sys.date).setHours(0, 0);
const dayEnd = new Date(sys.date).setHours(23, 59);
const now = new Date(sys.date).setHours(timeMatches[1]); // adjust for borked timezones in Homey v5
const dayProgress = roundDecimals((now - dayStart) / (dayEnd - dayStart), 4);
console.log('At', new Date(now).toLocaleTimeString([], { hour12: false }));
console.log('Day progress:\t\t', `${Math.round(dayProgress * 100)}%`);
// color temperature transitions from 1 to 0 to 1 during the day
temperature = roundDecimals((MAX_TEMPERATURE - (MAX_TEMPERATURE - MIN_TEMPERATURE) * getTemperaturePoint(dayProgress)));
console.log(`${VARIABLE_PREFIX}_Temperatur:\t`, temperature);
// brightness transitions from MIN to MAX to MIN during day
brightness = roundDecimals((MIN_BRIGHTNESS + (MAX_BRIGHTNESS - MIN_BRIGHTNESS) * getBrightnessPoint(dayProgress)));
console.log(`${VARIABLE_PREFIX}_Helligkeit:\t`, brightness);
await Homey.logic.updateVariable({id: 'b042b591-48f9-4803-a9af-3d115ac2a95b', variable: { value: temperature } });
await Homey.logic.updateVariable({id: '2074ddcf-92b2-42eb-a4f2-2c32de90a96a', variable: { value: brightness } });
return true;
The Homey logic variables I use are called:
– Circadian\_Helligkeit
– Circadian\_Temperatur
If you want to rename the variables, then the following red marked words must be changed:
```auto
In these two lines the IDs of the variable must be entered:
```auto
The variable IDs are received by running the following script:
```auto
Homey.logic.getVariables().then(r => log(r))
_[View the full topic](https://community.homey.app/t/diy-circadian-rhythm-based-lighting/33348)._
