# Dimmer / switch for 2 light groups
**URL:** <https://community.homey.app/t/dimmer-switch-for-2-light-groups/14325>\
**Created:** [June 12, 2019, 6:56am UTC](https://community.homey.app/t/dimmer-switch-for-2-light-groups/14325 "2019-06-12T06:56:19Z")\
**Author:** ![Jamie](https://sea1.discourse-cdn.com/flex025/user_avatar/community.homey.app/jamie/32/5274_2.png) [@Jamie](https://community.homey.app/u/Jamie)\
**Post date:** [June 13, 2019, 5:13am UTC](https://community.homey.app/t/dimmer-switch-for-2-light-groups/14325/2 "2019-06-13T05:13:45Z")
Just be aware you will not be able to use a HUE light with directly connected dimmer.
If you want to be able to ‘dim’ a hue light - rather then adjust voltage - as you would in a normal globe - you instead need keep the voltage constant and to inform the globe to dim itself.
The alternative is to use a dimmer/switch which is not connected directly to the globe, which when adjusted triggers a flow which adjusts the hue globes brightness. (ie. Smart wireless controller : [https://www.fibaro.com/en/products/smart-switches-and-outlets/](https://www.fibaro.com/en/products/smart-switches-and-outlets/)) or [Smart lighting | Philips Hue US](https://www2.meethue.com/en-au/p/hue-dimmer-switch/8718696752029)
But to answer your question, the standard way is to use a device like fibaro/aeotec dimmer hooked up to momentary button switch. - Which by default will adjust the brightness by holding the button down - and double click to go to 100%.
You may find this useful
> [@Starting with Homey - smart bulbs (Philips HUE)+light switch+fibaro dimmer?](https://community.homey.app/t/starting-with-homey-smart-bulbs-philips-hue-light-switch-fibaro-dimmer/3466/4):
> Its a long post, but the short answer to your question is ‘yes but depends’. In regards to your original requirements. All of this, other than the RBGW is possible using the Fibaro switch/dimmer the dimmer2 can ever carry a second scene upon it so that you. can use another button to turn on/off sonos. The interesting part is the RGB lights, there are a couple of things to know Smart globes and power surges do not mix well. (ie turn on/off) Smart globes and dimmers do no mix. (first hand ex…
v
_[View the full topic](https://community.homey.app/t/dimmer-switch-for-2-light-groups/14325)._
