# Danalock Zigbee stops functioning in Homey after short while
**URL:** <https://community.homey.app/t/danalock-zigbee-stops-functioning-in-homey-after-short-while/101591>\
**Category:** Devices\
**Tags:** zigbee, homey-pro\
**Created:** [January 18, 2024, 9:15pm UTC](https://community.homey.app/t/danalock-zigbee-stops-functioning-in-homey-after-short-while/101591 "2024-01-18T21:15:08Z")\
**Post date:** [January 19, 2024, 12:13am UTC](https://community.homey.app/t/danalock-zigbee-stops-functioning-in-homey-after-short-while/101591/2 "2024-01-19T00:13:40Z")
> [@Fredde\_Flumee](#):
> Why?? Solution, whats wrong. Need help!!
… 😅 Your not the only one, and we are just Homey users, not a company.
Please write to Danalock support as well, links are present at the Danalock page @ homey.app store
Hello Fredde,
Can you please read the guide below? Thx.
[https://community.homey.app/t/tip-problems-with-homey/35744](https://community.homey.app/t/tip-problems-with-homey/35744)
Can you provide for this info:
1.
Homey model? (hint: there are 3)
1.
Share your Homey zigbee overview, pls make a screenshot per [https://tools.developer.homey.app/tools/zigbee](https://tools.developer.homey.app/tools/zigbee)
1.
> Works fine in Danalock App
Tell me, which app on what platform do you mean by that, I can’t read your mind?
It can’t be an app on your phone while Danalock uses zigbee, and your phone doesn’t have a zigbee controller onboard
A zigbee device can be added to only ONE controller, presumably Homey in your case.
Is that correct?
But it doesn’t work @ Homey as I understand. So it can’t be the Homey Danalock app.
1.
> reinstall and after a few
What do you reinstall, and on which system?
1.
> Homekit.
Hmm what has Homekit to do with zigbee and Homey? I think this is irrelevant here.
1.
Did you change the Danalock batteries, even if they are ‘brand new’? Just replace them
1.
Did you tune your wifi and zigbee channels?
Do you have neighbours with (strong) wifi channels?
Please check and scan, and make adjustments if needed. Guide:
> **[ZigBee and Wi-Fi Coexistence](https://support.metageek.com/hc/en-us/articles/203845040-ZigBee-and-WiFi-Coexistence)**
> ZigBee and Wi-Fi channels both exist in the 2.4 GHz band, existing in the exact same frequency space. When deploying both Wi-Fi and ZigBee in the same environments, careful planning must be perform...
1.
Homey Pro 201x: Did you replace the power unit and the cable, with a decent quality one → 5V and 2A minimum
1.
Homey Pro 2023: did you replace the USB cables for decent quality ones, do you have the 5.2V power unit in place, or still using the 5.0V version?
_[View the full topic](https://community.homey.app/t/danalock-zigbee-stops-functioning-in-homey-after-short-while/101591)._
