# Can't connect zwave.me switch
**URL:** <https://community.homey.app/t/cant-connect-zwave-me-switch/30153>\
**Category:** Questions & Help\
**Created:** [May 20, 2020, 2:57pm UTC](https://community.homey.app/t/cant-connect-zwave-me-switch/30153 "2020-05-20T14:57:42Z")\
**Posts on this page:** 12\
**Page:** 1
<div class="post-metadata">
**Author:** ![Hans\_de\_Bruyne](https://sea1.discourse-cdn.com/flex025/user_avatar/community.homey.app/hans_de_bruyne/32/25207_2.png) [@Hans\_de\_Bruyne](https://community.homey.app/u/Hans_de_Bruyne)\
**Post date:** [May 20, 2020, 2:57pm UTC](https://community.homey.app/t/cant-connect-zwave-me-switch/30153/1 "2020-05-20T14:57:42Z")
</div>
I can’t connect my first z-wave device to Homey. It’s a [zwave.me](http://zwave.me) switch (2 wired).
[https://www.robbshop.nl/wandschakelaar-set-everlux-z-wave-me-zmee05434-3727](https://www.robbshop.nl/wandschakelaar-set-everlux-z-wave-me-zmee05434-3727)
The switch works manually, but I don’t get it connected to Homey. First of all, I can’t find the exact type id. The manual indicates 05434, 05462 and 05472. The app only shows 05431 and 05457. I tried both, but I get an error message after connecting “Something went wrong, try again later”.
The distance between the switch and Homey is about 8 meters, open space. Also tried right next to each other, same result.
Any ideas? Do I have to do/install something else first?
Please help.
Hans.
**Author:** ![Peter\_de\_Vos](https://sea1.discourse-cdn.com/flex025/user_avatar/community.homey.app/peter_de_vos/32/151925_2.png) [@Peter\_de\_Vos](https://community.homey.app/u/Peter_de_Vos)\
**Post date:** [May 20, 2020, 3:56pm UTC](https://community.homey.app/t/cant-connect-zwave-me-switch/30153/2 "2020-05-20T15:56:40Z")
</div>
Hi Hans,
Before adding to homey you have to reset de device first. You do this by pressing the on and off at the same time for a few seconds. While adding the homey close to device as possible. I use the zwave me app on homey
**Post date:** [May 20, 2020, 4:26pm UTC](https://community.homey.app/t/cant-connect-zwave-me-switch/30153/3 "2020-05-20T16:26:08Z")
</div>
Tried all that. Reset shows a red and green blinking light, instead of fast red blinking as stated by the manual.
Even with Homey on less than one meter, no success.
**Author:** ![DirkG](https://sea1.discourse-cdn.com/flex025/user_avatar/community.homey.app/dirkg/32/118897_2.png) [@DirkG](https://community.homey.app/u/DirkG)\
**Post date:** [May 20, 2020, 4:34pm UTC](https://community.homey.app/t/cant-connect-zwave-me-switch/30153/4 "2020-05-20T16:34:23Z")
</div>
It is indeed possible that this type is not supported by the app.
The following page is the official support page for the app. If you have any questions, just ask the question there or contact the programmer.
> [@Zwave.Me app](https://community.homey.app/t/zwave-me-app/9089):
> This app supports most [zwave.me](http://zwave.me) devices, including rebranding like Duwi. [https://apps.athom.com/app/me.zwave](https://apps.athom.com/app/me.zwave) Supported devices Supported Devices [image] Keyfob [image] WALLC-S - Scene Switch [image] WALLC-S V2 - Scene Switch [image] 054336Z - [Z-Wave.Me](http://Z-Wave.Me) dimmer [image] 054336 - Duwi built-in dimmer [image] 05439 - Schuko plugin dimmer [image] 064394 - Schuko plugin dimmer [image] 05461 - [Z-Wave.Me](http://Z-Wave.Me) Double Switch [image] 064367 - Düwi Blind Control v1.3 [image] 054367…
The inclusion of the first Z-Wave devices should be done as close as possible to the homey (a few cm!).
If you have built a good Z-Wave mesh later on, actuators can possibly be included at a greater distance.
Battery-powered devices **must always be included in close distance** to your home (a few cm!).
**Post date:** [May 20, 2020, 5:02pm UTC](https://community.homey.app/t/cant-connect-zwave-me-switch/30153/5 "2020-05-20T17:02:58Z")
</div>
Thanks Dirk. I will ask. The website of Robb’s showed the Talks with Homey logo, so I made a logical assumption. Robb’s doesn’t respond to my questions until now. Maybe they will later.
**Post date:** [May 20, 2020, 5:46pm UTC](https://community.homey.app/t/cant-connect-zwave-me-switch/30153/6 "2020-05-20T17:46:16Z")
</div>
Yeah, you’re right. Than you should be sure that the light switch works fine with Homey.
I’m really curious what Robbshop has to say about this.
**Author:** ![Hans\_Mol](https://sea1.discourse-cdn.com/flex025/user_avatar/community.homey.app/hans_mol/32/34952_2.png) [@Hans\_Mol](https://community.homey.app/u/Hans_Mol)\
**Post date:** [January 30, 2021, 1:18pm UTC](https://community.homey.app/t/cant-connect-zwave-me-switch/30153/7 "2021-01-30T13:18:57Z")
</div>
Hello hans.
Have the same problem as you. Did you ever find a solution. I used the switch on homeassistant perfectly identification 100% but switched to homey and now failure in adding
**Post date:** [January 30, 2021, 2:57pm UTC](https://community.homey.app/t/cant-connect-zwave-me-switch/30153/8 "2021-01-30T14:57:37Z")
</div>
Nee, nooit een oplossing gevonden. Bij Robbs erkenden ze dat het Homey logo er niet bij had mogen staan en ik heb hem teruggestuurd.
**Author:** ![Berni](https://sea1.discourse-cdn.com/flex025/user_avatar/community.homey.app/berni/32/9528_2.png) [@Berni](https://community.homey.app/u/Berni)\
**Post date:** [January 31, 2021, 10:05am UTC](https://community.homey.app/t/cant-connect-zwave-me-switch/30153/9 "2021-01-31T10:05:25Z")
</div>
The [zwave.me](http://zwave.me) app needs to be rewritten to work with Homey v5, it is working with the last stable version.
**Post date:** [February 3, 2021, 3:52pm UTC](https://community.homey.app/t/cant-connect-zwave-me-switch/30153/10 "2021-02-03T15:52:00Z")
</div>
bedankt, helaas omdat dit de enige tweedraads schakelaar is die ik kan vinden. werkte perfect in homeassistant.
heb support trouwens gevraagd voor ondersteuning van deze schakelaar
**Post date:** [February 3, 2021, 4:29pm UTC](https://community.homey.app/t/cant-connect-zwave-me-switch/30153/11 "2021-02-03T16:29:28Z")
</div>
Use dimmers from [zwave.me](http://zwave.me) for that reason.
**Post date:** [February 4, 2021, 9:15am UTC](https://community.homey.app/t/cant-connect-zwave-me-switch/30153/12 "2021-02-04T09:15:25Z")
</div>
Thats why i use homey because it can connect multi brands of one platform. This switch seems to be dropped out of the supported range
