# Boiler slimmer maken via dimmer
**URL:** <https://community.homey.app/t/boiler-slimmer-maken-via-dimmer/73850>\
**Category:** Vragen & hulp\
**Created:** [December 19, 2022, 5:24pm UTC](https://community.homey.app/t/boiler-slimmer-maken-via-dimmer/73850 "2022-12-19T17:24:49Z")\
**Showing post:** 121
**Author:** ![FKey](https://sea1.discourse-cdn.com/flex025/user_avatar/community.homey.app/fkey/32/14793_2.png) [@FKey](https://community.homey.app/u/FKey)\
**Post date:** [January 13, 2025, 8:37pm UTC](https://community.homey.app/t/boiler-slimmer-maken-via-dimmer/73850/121 "2025-01-13T20:37:18Z")
Ik probeer met mijn auto lader ongeveer hetzelfde te bereiken: alle overschot de auto in.
De flow die ik heb werkt inmiddels prima.
De teruglevering is heel laag.
Misschien dat je er inspiratie van opdoet…
> [@\[APP\] Amina - Power up your smart home with Amina S](https://community.homey.app/t/app-amina-power-up-your-smart-home-with-amina-s/114193/6):
> Surplus solar energy charging Only use the surplus of your solar energy to charge your EV. To minimise your energy returned to grid. (Remember, EV’s generally require a minimum of 6A (1.4kW) to start charging) Amina app v2.0.1 (currently the latest) is lacking functionality to support surplus solar energy charging Amina app v2.1.0 (27 Aug) now supports single phase charging, I will update the flow below with the new card The surplus of solar panels is less than 18A in most common cases. (…
_[View the full topic](https://community.homey.app/t/boiler-slimmer-maken-via-dimmer/73850)._
