[APP] Aqara & Xiaomi Smart Home - A different kind of Smart Home solution (Zigbee App)
So there is still a plugin, but there through the mi hub
So I wrote to the developer! Why are you butting in and finding fault with words?
I feel a line coming here.
:popcorn:
It’s a public forum, if you don’t want people “butting in” send a private message to the developer.
For which sensor are you requesting this change?
Can you share a diagnostics log from the app? in the app Settings > Apps > Aqara & Xiaomi Zigbee > send diagnostics log
Any update on the support of the aqara T1? :slight_smile: also would like to know if it will work with a normal manual switch
For Temperature/Humidity Sensor (round)
Yes, of course. Report sent e0c40ce5-775a-4da8-a1d6-82c1f2881fc9
The log doesn’t show temperature leggings (in the captured timeframe after the reboot at 15:24).
Are the sensors in reach? Can you try to trigger the sensor to start reporting; press the button and putting the sensor in your hands for a few minutes?
Then send a new diag log?
The sensors are not limited by the app to only report once every 0,5 degrees.
Busy (past) weeks… received the now also the second version.
Hope to have some time this weekend to work on the T1’s… but again: busy weeks
ba4c168c-53a1-4ae1-9857-f98f1420bc98
Yes, but to control underfloor heating I need to know the 0.1 degree change.
The temperature in the house changes by 0.1 degrees in 3-5 hours :slight_smile:
The results of the logging… this is off course a very fast excitation of the temperature, but the the data shows that there is no fixed limit in reporting delta / time
T dT dt
21.48
22.16 0.68 0:00:10
22.57 0.41 0:00:05
23.15 0.58 0:00:11
24.01 0.86 0:00:10
24.73 0.72 0:00:11
25.32 0.59 0:00:07
26.09 0.77 0:00:11
26.73 0.64 0:00:10
27.24 0.51 0:00:10
27.93 0.69 0:00:15
28.58 0.65 0:00:16
29.11 0.53 0:00:15
29.73 0.62 0:00:20
30.41 0.68 0:00:26
30.95 0.54 0:00:25
31.27 0.32 0:00:25
31.3 0.03 0:00:05
31.27 -0.03 0:00:11
It only reports when the temperature has changed by 0.5 degrees. If the temperature changes by 0.1 - 0.4. there will be no reports :frowning:
Well send me another report while cooling down (or check insights.homey.app)…
All changes are greater than 0.5 degrees:
053dbf5f-9eea-4f63-b706-1d33dd4b885c
“The temperature in the house changes by 0.1 degrees in 3-5 hours”
Is this the same building as the one we see the log a few posts above? I really don’t get it. Your temperture is changing by >0,4K every 10minutes or so. What is the problem?
Where do you see these changes? How did you come to the conclusion only deltas of 0.5 are reported?
The reason why the temperature changes so fast is that he should do a test.
For some reason the sensor is using this threshold, while I didn’t set these thresholds within the app.
Investigating the option to change the reporting thresholds for sensors is on my action list, but not on short term due to other commitments / priorities (e.g. adding the Aqara T1 devices)
I have the Aqara button but I don’t know how to distinguish multiple button presses. The only tag I can use with logic is ‘scene’, which is quite weird. What value is scene with a press?
Will there be support for the G2H cam? Although it’s not a Zigbee device I guess.
Should be easy to find out yourself by pushing a notification containing the value of the tag.
