Aqara & Xiaomi Smart Home - Zigbee App (v1.4.1 - TEST: v1.4.2)
I try so, but nothing changed.
The App dosent found any new device. Switch, Vibration, nothing. I try diverent timings for reset and search. try click button to keep alive with different timings.
Nothing. Restart Homey, restart app. no devices found. any other idears?
ok thats strange for me.
i was 20-30 cm away from the Homey and nothing work.
While I was trying to connect the sensor, my wife asked me to pull up the sun blind in the kitchen. When I got there, it suddenly said - successfully connected - on the cell phone.
Next test with the button (2018 version) - started the reset directly in the kitchen at the window and TADA - successfully connected - what’s the point now? 5 meters away is it possible and not directly near the headquarters?
Can it be that connecting via other devices in between works better than directly on the Homey?
Homey only supports a limited number (15, according to Athom) of directly connected Zigbee devices.
Does anyone happen to have any feedback on the tilt-angle data?
Please see:
Who comes up with that? After adding it, it will be used near the homey. 2 walls and heater are between where it was added (coincidentally actually) and where it is deployed. And there are other devices in the living room, why didn’t they find the device?
Basically, 15 devices isn’t really that much. Even with our 3 rooms, kitchen, bathroom, we have far more SmartHome devices (whereby ZigBee a little more and WiFi a little less) Alone via Tuja-Cloud there are already almost 15 WiFi devices, plus the Google parts (Chromecast, Hub, Mini) the LED lamps from HUE, etc., 15 is very, very tight, isn’t it?
Athom?
Homey Pro can handle up to 15 direct ‘children’. These are either routers or end devices that are connected directly to Homey.
This does not mean, however, that you can only connect 15 Zigbee devices in total to Homey Pro: devices can also be connected to Homey indirectly, via routers that relay the commands.
“a limited number of directly connected Zigbee devices
This doesn’t apply to WiFi devices or Zigbee devices that are managed by other hubs.
@TedTolboom FP1 presence sensor received - please let me know when you need testing in the field.
Roger
Hi @TedTolboom are you currently working on support for the Roller Shade Driver E1?
I received the FP1 just now. Would be great to add it. As it (hopefully) will significantly change the Dominica space. (Yes I have high hopes).
Attached the interview data
  "ids": {
    "modelId": "lumi.motion.ac01",
    "manufacturerName": ""
  "endpoints": {
    "endpointDescriptors": [
        "endpointId": 1,
        "applicationProfileId": 260,
        "applicationDeviceId": 65520,
        "_reserved1": 0,
        "inputClusters": [
          0,
          3,
          64704
        "outputClusters": [
          3,
          25
    "endpoints": {
      "1": {
        "clusters": {
          "basic": {
            "attributes": [
                "acl": [
                  "readable"
                "id": 0,
                "name": "zclVersion",
                "value": 3
                "acl": [
                  "readable"
                "id": 1,
                "name": "appVersion",
                "value": 54
                "acl": [
                  "readable"
                "id": 2,
                "name": "stackVersion",
                "value": 2
                "acl": [
                  "readable"
                "id": 3,
                "name": "hwVersion",
                "value": 1
                "acl": [
                  "readable"
                "id": 4,
                "name": "manufacturerName",
                "value": "aqara"
                "acl": [
                  "readable"
                "id": 5,
                "name": "modelId",
                "value": "lumi.motion.ac01"
                "acl": [
                  "readable"
                "id": 6,
                "name": "dateCode",
                "value": "20210121"
                "acl": [
                  "readable"
                "id": 7,
                "name": "powerSource",
                "value": "dc"
                "acl": [
                  "readable"
                "id": 13
            "commandsGenerated": [],
            "commandsReceived": [
              "factoryReset"
          "identify": {
            "attributes": [
                "acl": [
                  "readable"
                "id": 0
              0
        "bindings": {
          "identify": {
            "attributes": [
                "acl": [
                  "readable"
                "id": 0
              0
          "ota": {}
Hello @tedtolboom
Will the aqara curtain Driver E1 supported for homey??
Greetz François
Yesss i’m interested too👍
Can you add Aqara Zigbee termostat?
@TedTolboom waiting patience for the aqara E1 curtain Driver :blush: thanks for the good work so far :muscle::birthday:
I think you accidentally typed “patient” in your sentence…
It was meant to be a bit sarcastic. Patient was the right word, but you are not patient at all imho…
Hi, will the Aqara H1 Wireless Single Switch be supported anytime soon? Or can you use the Aqara H1 Wireless Switch Double for the singe switch as well?
??? I’m patience, good things you don’t want to rush😉
i have ordered an aqara smoke detector, when i connect it it says "cannot find installed app the device is connected as unknown zigbee device’
Can you help?
