[APP] Aqara & Xiaomi Smart Home - A different kind of Smart Home solution (Zigbee App)
Anyone with Aqara Wall Switch H1 and Homey Bridge? I can’t connect 3 at the same time. The Bridge only connect one, if i connect one of the 3 homey don’t recognize the otheres
Are all switches of the “No Neutral” version?
The H1 switches with Neutral are not yet supported and will result in not being recognized…
Yes they are all “No Neutral” version. Maybe it’s a bridge problem? I see now my ikea roller blind lost the connect when i connect one Aqara H1. Seems the bridge only allow 1 zigbee device
Edit: after the problema with aqara h1 o can’t connect any zigbee devices with homey bridge. My aqara’s cube don’t work anymore. I try to recconect and i can’t. In the first time recognize the aqara cube but can’t connect. The second time don’t recognize the aqara cube. I resete the homey bridge and nothing.
Replace battery and wait - if it will not help, press any button on the sensor - if it will also not help, pair it again WITHOUT removing. You will not lose insights for any of those actions but if you would like to be sure, you can back it up using Archive Insights App for Homey | Homey
Thanks I re-paired it and it worked.
I just installed a bathroom fan and planned to trigger it based on the humidity value of my aqara temperature sensor. But there are no flowcards for this? Or am I missing something?
I searched some more and found this:
And used this as condition:
In which the blue tag is from my aqara bathroom sensor.
But my remaining question now is, which sensor triggers this flow? Or any humidity sensor change in the whole house?
Ok….
Homey is just acting weird. Or the homey app probably. I found it. Sometimes when I go to set a trigger:
If> Aqara & Xiami zigbee > Bathroom sensor
I can only choose a few options (temp amongst others). But when I try 3 more times I can choose the trigger I need:
So problem solved but strange behavior remains when making flows…
Hey Ted,
do you have any estimate when H1 switches with Neutral could be added? I have lumi.switch.n2aeu1, Smart Wall Switch H1 EU (With Neutral, Double Rocker), model WS-EUK04, SKU: AK074EUW01, produced 2021.06
Thank you,
Frank
Interview:
"ids": {
    "modelId": "lumi.switch.n2aeu1",
    "manufacturerName": "LUMI"
  "endpoints": {
    "endpointDescriptors": [
        "endpointId": 1,
        "applicationProfileId": 260,
        "applicationDeviceId": 256,
        "_reserved1": 1,
        "inputClusters": [
          0,
          2,
          3,
          4,
          5,
          6,
          9,
          1794,
          2820
        "outputClusters": [
          10,
          25
        "endpointId": 2,
        "_reserved1": 1,
        "inputClusters": [
          0,
          3,
          4,
          5,
          6
        "outputClusters": []
        "endpointId": 242,
        "applicationProfileId": 41440,
        "applicationDeviceId": 97,
        "_reserved1": 0,
        "inputClusters": [],
        "outputClusters": [
          33
    "endpoints": {
      "1": {
        "clusters": {
          "basic": {
            "attributes": [
                "acl": [
                  "readable"
                "id": 0,
                "name": "zclVersion",
                "value": 3
                "acl": [
                  "readable"
                "id": 1,
                "name": "appVersion",
                "value": 22
                "acl": [
                  "readable"
                "id": 2,
                "name": "stackVersion",
                "value": 2
                "acl": [
                  "readable"
                "id": 3,
                "name": "hwVersion",
                "value": 1
                "acl": [
                  "readable"
                "id": 4,
                "name": "manufacturerName",
                "value": "LUMI"
                "acl": [
                  "readable"
                "id": 5,
                "name": "modelId",
                "value": "lumi.switch.n2aeu1"
                "acl": [
                  "readable"
                "id": 6,
                "name": "dateCode"
                "acl": [
                  "readable"
                "id": 7,
                "name": "powerSource",
                "value": "mains"
                "acl": [
                  "readable"
                "id": 65533,
                "name": "clusterRevision",
                "value": 1
            "commandsGenerated": [],
            "commandsReceived": [
              "factoryReset"
          "deviceTemperature": {
            "attributes": [
                "acl": [
                  "readable"
                "id": 0,
                "name": "currentTemperature",
                "value": 34
                "acl": [
                  "readable",
                  "writable"
                "id": 16,
                "name": "deviceTempAlarmMask",
                "value": {
                  "type": "Buffer",
                  "data": [
                    2
                "acl": [
                  "readable",
                  "writable"
                "id": 18,
                "name": "highTempThreshold",
                "value": 70
                "acl": [
                  "readable",
                  "writable"
                "id": 20,
                "name": "highTempDwellTripPoint",
                "value": 3
                "acl": [
                  "readable"
                "id": 65533,
                "value": 1
            "commandsReceived": []
          "identify": {
            "attributes": [
                "acl": [
                  "readable",
                  "writable"
                "id": 0
                "acl": [
                  "readable"
                "id": 65533,
                "value": 1
              0
              0,
              1
          "groups": {
            "attributes": [
                "acl": [
                  "readable"
                "id": 0,
                "name": "nameSupport",
                "value": {
                  "type": "Buffer",
                  "data": [
                    128
                "acl": [
                  "readable"
                "id": 65533,
                "value": 1
              "addGroup.response",
              "viewGroup.response",
              "getGroupMembership.response",
              "removeGroup.response"
              "addGroup",
              "viewGroup",
              "getGroupMembership",
              "removeGroup",
              "removeAllGroups",
              "addGroupIfIdentify"
          "scenes": {
            "attributes": [
                "acl": [
                  "readable"
                "id": 0
                "acl": [
                  "readable"
                "id": 1
                "acl": [
                  "readable"
                "id": 2
                "acl": [
                  "readable"
                "id": 3
                "acl": [
                  "readable"
                "id": 4
                "acl": [
                  "readable"
                "id": 5
                "acl": [
                  "readable"
                "id": 65533,
                "value": 1
              0,
              1,
              2,
              3,
              4,
              6,
              64,
              65,
              66
              0,
              1,
              2,
              3,
              4,
              5,
              6,
              64,
              65,
              66
          "onOff": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "name": "onOff",
                "value": false,
                "reportingConfiguration": {
                  "direction": "reported",
                  "attributeDataType": 16,
                  "minInterval": 1,
                  "maxInterval": 61,
                  "status": "SUCCESS"
                "acl": [
                  "readable"
                "id": 16384
                "acl": [
                  "readable"
                "id": 65533,
                "value": 1
              "setOff",
              "setOn",
              "toggle"
          "alarms": {
            "attributes": [
                "acl": [
                  "readable"
                "id": 0
                "acl": [
                  "readable"
                "id": 65533,
                "value": 1
              0,
              "resetAllAlarms"
              0,
              "resetAllAlarms",
              "getAlarm",
              "resetAlarmLog"
          "metering": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "name": "currentSummationDelivered",
                "value": 0,
                  "attributeDataType": 37,
                  "minInterval": 120,
                  "maxInterval": 300,
                  "minChange": 1,
                  "status": "SUCCESS"
                "acl": [
                  "readable"
                "id": 512
                "acl": [
                  "readable"
                "id": 768
                "acl": [
                  "readable"
                "id": 769,
                "name": "multiplier",
                "value": 1
                "acl": [
                  "readable"
                "id": 770,
                "name": "divisor",
                "value": 1000
                "acl": [
                  "readable"
                "id": 771
                "acl": [
                  "readable"
                "id": 772
                "acl": [
                  "readable"
                "id": 774
                "acl": [
                  "readable"
                "id": 65533,
                "value": 1
              0,
              3,
              1
              0,
              3,
              1,
              2
          "electricalMeasurement": {
            "attributes": [
                "acl": [
                  "readable"
                "id": 0,
                "name": "measurementType",
                "value": {
                  "type": "Buffer",
                  "data": [
                    8,
                    0,
                    0,
                    0
                "acl": [
                  "readable"
                "id": 1291,
                "name": "activePower",
                "value": 0
                "acl": [
                  "readable"
                "id": 1540,
                "name": "acPowerMultiplier",
                "value": 1
                "acl": [
                  "readable"
                "id": 1541,
                "name": "acPowerDivisor",
                "value": 10
                "acl": [
                  "readable",
                  "writable"
                "id": 2048,
                "name": "acAlarmsMask",
                "value": {
                  "type": "Buffer",
                  "data": [
                    4,
                    0
                "acl": [
                  "readable"
                "id": 2051,
                "name": "acActivePowerOverload",
                "value": 2500
                "acl": [
                  "readable"
                "id": 65533,
                "value": 1
        "bindings": {
          "time": {},
          "ota": {}
      "2": {
        "clusters": {
          "basic": {
            "attributes": [
                "acl": [
                  "readable"
                "id": 0,
                "value": 3
                "acl": [
                  "readable"
                "id": 1,
                "value": 22
                "acl": [
                  "readable"
                "id": 2,
                "value": 2
                "acl": [
                  "readable"
                "id": 3,
                "value": 1
                "acl": [
                  "readable"
                "id": 4,
                "value": "LUMI"
                "acl": [
                  "readable"
                "id": 5,
                "name": "modelId",
                "acl": [
                  "readable"
                "id": 6,
                "name": "dateCode"
                "acl": [
                  "readable"
                "id": 7,
                "value": "mains"
                "acl": [
                  "readable"
                "id": 65533,
                "value": 1
              "factoryReset"
          "identify": {
            "attributes": [
                "acl": [
                  "readable",
                  "writable"
                "id": 0
                "acl": [
                  "readable"
                "id": 65533,
                "value": 1
              0
              0,
              1
          "groups": {
            "attributes": [
                "acl": [
                  "readable"
                "id": 0,
                "value": {
                  "type": "Buffer",
                  "data": [
                    128
                "acl": [
                  "readable"
                "id": 65533,
                "value": 1
              "addGroup",
              "viewGroup",
              "removeGroup",
              "removeAllGroups",
          "scenes": {
            "attributes": [
                "acl": [
                  "readable"
                "id": 0
                "acl": [
                  "readable"
                "id": 1
                "acl": [
                  "readable"
                "id": 2
                "acl": [
                  "readable"
                "id": 3
                "acl": [
                  "readable"
                "id": 4
                "acl": [
                  "readable"
                "id": 5
                "acl": [
                  "readable"
                "id": 65533,
                "value": 1
              0,
              1,
              2,
              3,
              4,
              6,
              64,
              65,
              66
              0,
              1,
              2,
              3,
              4,
              5,
              6,
              64,
              65,
              66
          "onOff": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "name": "onOff",
                "value": false,
                  "minInterval": 1,
                  "maxInterval": 61,
                  "status": "SUCCESS"
                "acl": [
                  "readable"
                "id": 16384
                "acl": [
                  "readable"
                "id": 65533,
                "value": 1
              "setOff",
              "setOn",
              "toggle"
        "bindings": {}
      "242": {
        "clusters": {},
        "bindings": {}
Hi Robert.
The Conbee II is an usb Stick how is this gone work with homey ?
Through the deCONZ app. But you’re going to need additional hardware to host the USB stick and software, like a Raspberry Pi or a NAS.
Dear Ted, I ordered a bunch of new Aqara H1 (EU) ZigBee Switches - but they end up as unknown devices. Via the FB Community I was pointed here.
I guess the H1 switch with Neutral wire?
They are not supported yet.
If all goes well, and the boss at home approves, I would expect to have support for these switches available end of next week in the app…
Haha, fair point! I will wait for it with pleasure! Feel free to buy the Mrs a bottle of wine on my expenses :slight_smile:
That’s great Ted, thank you!
That’s always much appreciated!
This works for me, the aqara (lumi) sensor is really sensitive. I didn’t remove that left lower white rubber so the impact is higher, maybe that is the issue? My flow just checks on movement (beweging) and it works like a charm.
Same problem here.
Don’t know what to do, I have paired it all over and it works for sometime then I stopped again. And it’s always over night
Hello, all can anyone point me to the complete list of supported device?
I dont mean just the name + picture listed on the result of App name search.
I mean the exact model number (there could be some variants across different countries).
