[APP][PRO] Sensibo
For Sensibo Sky, Sensibo Air, Sensibo Pure and Sensibo Room Sensors.
App store: Sensibo App for Homey | Homey
To install:
  1. Get an API-key from https://home.sensibo.com/me/api
  2. Set the API-key during pairing of the device
Device: Sensibo
Triggers
  • The target temperature changed.
  • Thermostat mode changed.
  • The temperature changed.
  • The humidity changed.
  • Device turned on.
  • Device turned off.
  • Device offline.
  • Timer created.
  • Timer fired.
  • Timer deleted.
  • AC state changed.
  • Climate React changed.
Conditions
  • Thermostat mode is.
  • Is on.
  • Climate React is enabled / disabled.
  • Timer is enabled / disabled.
Actions
  • Set the temperature.
  • Set the mode (Automatic, Heat, Cool, Off)
  • Turn on.
  • Turn off.
  • Set the fan mode.
  • Set the fan level.
  • Set Swing mode.
  • Set Horizontal swing mode.
  • Control Climate React.
  • Control Pure Boost.
  • Control light.
  • Sync power state.
  • Set timer.
  • Delete timer.
Capabilities
  • On / off
  • Fan level
  • Fan mode
  • Target temperature
  • Swing
  • Horizontal swing
  • Climate React
  • Temperature
  • Humidity
  • Last seen
Device: Sensibo Pure
Triggers
  • Device turned on.
  • Air quality changed.
  • Device offline.
  • Timer created.
  • Timer fired.
  • Timer deleted.
Conditions
  • Is on.
Actions
  • Turn on.
  • Turn off.
  • Control light.
  • Set timer.
  • Delete timer.
Capabilities
  • On / off
  • Fan level
  • Temperature
  • Humidity
  • Last seen
Device: Sensibo Room Sensor
Triggers
  • Device offline.
Capabilities
  • Temperature
  • Humidity
  • Last seen
Release Notes:
1.10.1
  • Added Control Pure Boost action for Sensibo Pure
  • Options for lights (on, off, dim) are now fetched from remote capabilities
1.10.0
  • Added support for Sensibo Pure and Sensibo Room Sensor
1.9.5
  • Added horizontal swing (capability and action card)
  • Added action to sync the power state
  • Added action to control Pure Boost
  • Added action to control the AC light
  • Added fan levels (Medium high, Medium low, Quiet)
  • Fixes for pairing
1.8.0
  • Changed minimum temperature to 10 deg. C
  • Updated to SDK 3
1.7.1
  • Minor bug fix
1.7.0
  • Dynamic list of modes and fan levels when setting from flows
1.6.1
  • Added triggers for timers
V. 1.1.0 with support for swing mode:
167 posts were merged into an existing topic: [APP][Pro] Sensibo - new maintainer
A post was merged into an existing topic: [APP][Pro] Sensibo - new maintainer
Due to the takeover of the app by @OH2TH, all posts have been moved to the new topic [APP][Pro] Sensibo - new maintainer and this topic has been closed.
