@Jan-Feijen thanks a lot for you donation! appreciated.
Can you enable debug in the device settings (in homey) and send a new report after that. It will create some more logging which should make clear whats going on.
One question though, does your car use a S-PIN? If yes then that would be a way to identify what type you should select during pairng
I’ve enabled debug. I assume I need to retry the actions so you can seem them in the logs, anything in particular so you can debug?
I think I’ve a S-Pin. During verification of myaudi account 2 years ago I had to enter a pin. So I think that is my S-Pin. Also when I installed your myaudi app yesterday I had to enter it to lock/unlock the car. Which worked fine when entered.
But I entered it when trying to lock/unclock but NOT during installing the app. Maybe that would have helped during pairing?
An other observation: when installing your app yesterday with the ‘audi’ option the app recognised the type of my car. Which didn’t happen when installing the app with the ‘e-tron’ option.
@Jan-Feijen as your using HP23 the report is really short. Is it possible to start an action and immediately send a report after that?
Then maybe I can see what’s going on.
I have no flow active with the skoda app. Only notifications. Like when battery is fully charged and when car comes home.
I got some warning message in my regular Android skoda app that my climate request was denied . Too many requests in short time and it was denied to save the battery-life.
That happened two times and stopped when I removed it from homey. Can this problem be connected with homey?
@JaccoH Sorry had some private priorities last days.
Checked your report, but you’re still on app version 1.1.5.6 and not the test version. Can you click this link and press the green install button? MyŠKODA | Homey
@Jan-Feijen checked you report too (sorry a bit later than promised, but had some other things going on )
The issue you have seems like an driver issue, is your car on the latest software?
I saw this before and then the solution was to choose the other car type in the pairing screen, but you already did that ofcourse…
So let’s check the version of your software in the car then we can maybe see which API is relevant for your car.
VW has a clear distinction between the 2, but unfortunately Audi doesn’t
Edit: for your info:
[debug] {"error":{"errorCode":"RS.security.9007","description":"The service: rheating_v1 for VIN: REDACTED could not be found."}}
This most of the time indicates that you have to use the new API
