Debug enabled.
Report sent d1102b74-a73e-495f-a34a-065242ef0c01
@OH2TH i made a typo in the mapping
I have odoMeter but should be odometer.
Will fix tomorrow
Tnx, will turn debug off now.
New app update (test: 1.10.1)
Changelog:
- NEW: is climatisation on/off flowcard (hybrid/electric)
- NEW: is climatisation on/off sensor (hybrid/electric)
- NEW: is climatisation on/off connected to button (hybrid/electric)
- NEW: add odometer (driven mileage) to ID cars
New app update (test: 1.10.0)
Changelog:
Changelog:
- NEW: Skoda V3 API support
Changelog:
New app update (test: 1.11.0)
@OH2TH odometer should be fixed
Thank you, indeed odometer is now working for VW ID.3.
Changelog:
Changelog:
Changelog:
- FIX: missing flowcards for multiple models (Cupra & Skoda)
Changelog:
New app update (test: 1.11.1)
@Martin_1985 missing flowcards are fixed in this test version
Thanks! It’s working fine now!
Keep up the good work!!
Thanks for adding the feature.
The “staat klimaatbeheer aan” is unchanged for 9 days. There has also been some issues on the carnet api so waited to respond to be sure ….
Please let me know if you need anything to troubleshoot.
Greets, Bug
@Bug looks like this value doesn’t change in the API
Checked it together with @Sharkys and it stays on the same value.
But will investigate
@martijnpoppen
The we connect app does toggle but I am unsure what value changes.
If there is a way to see what changes in the api between changes we should be able to find it…
Is that enabled with the debug option maybe?
Yeah when you enable Debug all API responses are logged
Will do the clima changes and check the we connect app for the change to appear and the homey app to update (something else and send you the logs.
77b89fba-67c1-4d5e-b2bd-8a2e84c758cd
Hi Martijn,
I have installed you’re app and I have We-connect application. After my username and password and the S-pin ( double check and change password). It’s going back to login and need to reply my username and password again… After S-PIn recieving data from the server and going back to login…
Username and password are correct…
Hey @Martijn_Van_Neerven
If you’re going back to the login screen your credentials are not correct or the car could not be found
Make sure to use your main account and not a guest account
I login with the same settings orginele app.
When i do a wrong username it’s give me a error can’t pair the device. I know 100% it’s the good settings.
You need a we connect plus subscription? That’s the only thing I don’t have…
Yes without it wont work. But still should see your car.
Can send a diagnostic report?
Sure
1ff25c41-e955-4df8-a4cd-4c06bfcf0247
I did see in the app documentation that we should be able to change the Charge-limit on Skoda Enyaq, but I can’t find that flow-card… what am I doing wrong?
Hey @Mari_VW
I could take a look at that.
Can you share the possibilities of elli with me?
Not sure what you can do with the app
