Hi all, I feel quite stupid asking this, but I have been reading and playing around with no luck. Ok, so the thing is that I’m trying to set a thermostat for both heating and cooling, so that it would have not only a target temperature but a target range, let’s say [20,27]. Then in auto whenever it goes below or above it would control either the heating or the cooler, so it would be useful all year round.
Any ideas how to make it something like this? Thanks in advance!
And if something is missing, DC and the AVDs is fully worked on, so just let me now.
(Custom Dropdowns are on the list, just haven’t found a “real” solution yet, only a very dirty one.)
Take a look at the AVD Template: Changing a button/field name through flows
It also shows the custom icon you can pick for a list of 80 custom icons, that you can set to any default icon or your own!
Take a look at the AVD of DC; you can add and change fields whenever, and set the decimals, min/max and step just how you want it!
Hey @Bonden , take a look at the AVD’s of the DC App.
Not only can you change a device icon after creation, you can alter the field/capability icons just how you like it.
Take a look at the AVD Template for Living Room Example, it has three nice custom icons.
Well, maybe the icons are not that nice, but you can even upload your own icon!
Hey @Heula, take a look at the App Device Capabilities, it has an Advanced Virtual Device that you can configure anywhich way you want!
Hey @nytro , with the AVD from DC you can! There are flow cards (which you can execute from HS i guess ) with which you can set values!
If I read the beginning op the post @Arie_Laxed likes to have this app developed by some other talent. Is there already someone on it for the 2023 version? This is for me a basic used app because of the without no trigger option that the experiment homey option not have for toggle switches/ modes.
The Virtual Devices App has just been transfered to me by @Arie_Laxed
That means:
It will be updated to SDK3.
Sourcecode will me moved over to BitBucket where a new issue/support-ticket-system wil be started.
I will (try to) work through the current issue list from GitHub, after SDK3 is done.
Now that the sourceode and VD app is in my control, i want to add a feature, based on the AVD’s:
The ability to change a custom device icon after creation.
Any VD with a custom icon that was uploaded while creating the VD, can be altered after creation, just like with the AVDs.
Unfortuantly, this cannot be done with items picked from the default icons during device creation.
I might change this for new VDs in the same way as with AVDs: wether you pick one from the defaults or upload a custom icon, you will be able to change it after creation.
(Possibly) a Integration or Migration tool between AVD and VD’s.
Like @Arie_Laxed says in this Main Topic Post: The VD sourceode is ‘outdated’ and perhaps the VD app should be refreshed. He advices to create several, more specific Apps.
But that has already been done:
The Advanced Virtual Devices from the Device Capabilities App is a fully customisable virtual device, which you can complete configure yourself.
While the VD app is, in it’s core, more focused on Default “Athom” capabilities and extending those features.
That means that some users with VDs might be better surved with AVDs and vice versa.
And since the AVD (DC App) has the functionalities of the Share Your Device! - Advanced Virtual Devices from Device Capabilities - Apps (SYD) and the The Flow Exchange(r) - Exchange Your Flows with Others! (TFE), there might be some excellent ways the apps can work together, synchronise and/or migrate between them.
Well this is just a start, currently i am starting of with setting up the develop environment, sourcecontrol, stuff like that. Then i’ll work on SDK3.
Yes, but I use only some light switches for on/off, that’s all.
And I’m in the process of creating these devices with ADC to reduce the number of apps I have.
I am gonna change the topic a bit, This is a reminder message:
This is the Old Topic Post up until i, @Arie_J_Godschalk took over on 26-10-2022.
Important Note:
This app is no longer updated. It works how it works.
My last update was 15 months ago and facing reality: Homey is developing much quicker than I can keep up. With the new release of Homey Bridge and support for TypeScript, it makes sense to start from scratch and create a new Virtual Devices v2 app that follows the latest standards.
That won’t be me, though. I have different interests. Perhaps in the future…, but no, don’t wait for that.
Feel free to take the name, the ideas and even parts of the code. In fact I would like that very much.
I can advice to create several apps:
1 App for pure Virtual Devices, supporting only the capabilities provided by Athom
1 App for sensors, with the freedom to combine multiple (sensor-)capabilities into 1 app
1 App for modes, maybe give the multi-mode a new try
Specific apps for specific request. E.g. Garage doors, Swimming pools, etc.
Thanks for all the compliments, questions, and help.
With kind regards,
Arjan
Virtual Devices can simulate anything without using an actual interface. Well… of course within the limits that Homey provides.
