[APP][Pro] Tuya Zigbee App
…a pity it’s not battery operated but the sensitivity looks great.
You could build yourself a 230V battery and hide it in the ceiling?
:laughing:
Hi all,
Since a week or 2 my tuya zigbee app stops working random and shows a pause symbol in the app list. All tuya zigbee devices have a warning sign. And to make things worse, it sometimes switches metering plugs off by itself (not all, only one, but not always the same).
I am using the experimental version in order to add the metering plugs, they aren’t supported in the standard version.
Does anyone else experience the same? Anyone know if there might be a solution for this behavior?
Thanks!
Robert
Random stuff happening on Homey can be caused by a failing power supply. The original Athom power supply that comes with Homey is known to be of very bad quality, so if you’re still using that, replace it with something else (5V, 2.1A or more, don’t use cheap Chinese USB chargers).
Missing the Tuya Rail Switch. Now recognized as unknown zigbee device, so just on/off. Missing the power info.
Adding this device would be really appreciated since I have a lot of them.
Thanks.
To be able to add more devices I will need help with interviews of the devices you want added. Anyone asking for a device to be added will have to have: …”
How can I help?
Exactly the same issue here. I’ve been pulling my hair out and have tried everything to a new power supply (a good one), new USB cable, resetting the Zigbee network and a full factory reset.
Plugs randomly switching off is a known issue with Tuya plugs. There’s a firmware update for them but you’ll need a Tuya hub or Home Assistant to do that. I’ve updated all my plugs with Home Assistant / ZHA and since them no more random switching off.
Haven’t added them back to Homey yet. I suspect the issues are related to whether the plugs push information or have to be polled by Homey / this app. Different firmware versions have different behavior, so there might be something going on there. 0.23 of this app worked fine for me, but higher versions not.
  "ids": {
    "modelId": "TS011F",
    "manufacturerName": "_TZ3000_qeuvnohg"
  "endpoints": {
    "endpointDescriptors": [
        "endpointId": 1,
        "applicationProfileId": 260,
        "applicationDeviceId": 266,
        "_reserved1": 1,
        "inputClusters": [
          0,
          3,
          4,
          5,
          6,
          1794,
          2820,
          1026,
          57344,
          57345
        "outputClusters": [
          25,
          10
        "endpointId": 242,
        "applicationProfileId": 41440,
        "applicationDeviceId": 97,
        "_reserved1": 0,
        "inputClusters": [],
        "outputClusters": [
          33
    "endpoints": {
      "1": {
        "clusters": {
          "basic": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "name": "zclVersion",
                "value": 3,
                "reportingConfiguration": {
                  "status": "NOT_FOUND",
                  "direction": "reported"
                "acl": [
                  "readable",
                  "reportable"
                "id": 1,
                "name": "appVersion",
                "value": 67,
                  "direction": "reported",
                  "attributeDataType": 32,
                  "minInterval": 1,
                  "maxInterval": 160,
                  "minChange": 0,
                  "status": "SUCCESS"
                "acl": [
                  "readable",
                  "reportable"
                "id": 2,
                "name": "stackVersion",
                "value": 0,
                "acl": [
                  "readable",
                  "reportable"
                "id": 3,
                "name": "hwVersion",
                "value": 1,
                "acl": [
                  "readable",
                  "reportable"
                "id": 4,
                "name": "manufacturerName",
                "value": "_TZ3000_qeuvnohg",
                "acl": [
                  "readable",
                  "reportable"
                "id": 5,
                "name": "modelId",
                "value": "TS011F",
                "acl": [
                  "readable",
                  "reportable"
                "id": 6,
                "name": "dateCode",
                "value": "",
                "acl": [
                  "readable",
                  "reportable"
                "id": 7,
                "name": "powerSource",
                "value": "mains",
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 65502,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "name": "clusterRevision",
                "value": 2,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65534,
                "name": "attributeReportingStatus",
                "value": "PENDING",
                "acl": [
                  "readable",
                  "reportable"
                "id": 65504,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65505,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65506,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65507,
            "commandsGenerated": "UNSUP_GENERAL_COMMAND",
            "commandsReceived": "UNSUP_GENERAL_COMMAND"
          "identify": {
            "attributes": [
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 0,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 1,
          "groups": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "name": "nameSupport",
                "value": {
                  "type": "Buffer",
                  "data": [
                    0
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2,
          "scenes": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "acl": [
                  "readable",
                  "reportable"
                "id": 1,
                "acl": [
                  "readable",
                  "reportable"
                "id": 2,
                "acl": [
                  "readable",
                  "reportable"
                "id": 3,
                "acl": [
                  "readable",
                  "reportable"
                "id": 4,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2,
          "onOff": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "name": "onOff",
                "value": true,
                  "attributeDataType": 16,
                  "minInterval": 1,
                  "maxInterval": 65534,
                  "status": "SUCCESS"
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2,
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 16385,
                "name": "onTime",
                "value": 0,
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 16386,
                "name": "offWaitTime",
                "value": 0,
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 32769,
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 32770,
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 20480,
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 32768,
          "metering": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "name": "currentSummationDelivered",
                "value": 19,
                  "attributeDataType": 37,
                  "minInterval": 65534,
                  "maxInterval": 150,
                  "minChange": 1,
                  "status": "SUCCESS"
                "acl": [
                  "readable",
                  "reportable"
                "id": 512,
                "acl": [
                  "readable",
                  "reportable"
                "id": 768,
                "acl": [
                  "readable",
                  "reportable"
                "id": 771,
                "acl": [
                  "readable",
                  "reportable"
                "id": 774,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 1,
          "electricalMeasurement": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 1285,
                "name": "rmsVoltage",
                "value": 232,
                  "attributeDataType": 33,
                  "maxInterval": 151,
                  "minChange": 1,
                  "status": "SUCCESS"
                "acl": [
                  "readable",
                  "reportable"
                "id": 1288,
                "name": "rmsCurrent",
                "value": 50,
                  "maxInterval": 152,
                  "minChange": 1,
                  "status": "SUCCESS"
                "acl": [
                  "readable",
                  "reportable"
                "id": 1291,
                "name": "activePower",
                "value": 7,
                  "attributeDataType": 41,
                  "maxInterval": 153,
                  "minChange": 1,
                  "status": "SUCCESS"
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 1,
          "temperatureMeasurement": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "name": "measuredValue",
                "value": -630,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 1,
        "bindings": {
          "ota": {
            "attributes": [],
          "time": {
            "attributes": [],
      "242": {
        "clusters": {},
        "bindings": {}
Does anyone use this Tuya Mini Smart Human Motion Movement Body PIR from Aliexpress? Is it supported by the app?
I’m looking for cheep Zigbee motion sensors for a test involving outdoor lighting.
I have a few of them, though not in use with Homey (zigbee2mqtt instead).
It doesn’t look like it’s supported by this app (support was asked here), but even if it was, it wouldn’t mean that the ones that you would buy would work too, because lots of Tuya devices that look exactly the same have different internal identifiers that the app uses to recognise them.
With zigbee2mqtt they are pretty nice, with a configurable blind time (30/60/120s) and sensitivity (low/medium/high).
If you look around on Aliexpress a bit you can find them for cheaper, I think I paid €6.
Thank you robertklep,
That’s the main problem with buying from the big country in the east…you never know.
I might take a chance on one (and I did find cheeper ones than the one in my link) just to see if I can get it to work. There is always IKEA Trådfri (which I have one of) but there are basically no settings at all for them nowadays, and using motion sensors outdoor you really need to be able to adjust the sensitivity.
Hi Robert,
Already had that one replaced with a decent 12W version :grin:. I think it is more related to the new plugs I have added lately. To debug the issue, I have remover the last added plugs and it looks like the tuya app is stable again. Do you maybe know of a zigbee debugger? Something to sniff the network messages.
I think I indeed narrowed it down to the latest plugs. I will check the update possibility to see of they can be updatec to solve this. Otherwise I have 5 pcs of nice plugs with manual switch in it😁
Please add this LIDL lamp in RGB Bulb E14.
  "ids": {
    "modelId": "TS0505B",
    "manufacturerName": "_TZ3000_th6zqqy6"
  "endpoints": {
        "endpointId": 1,
        "applicationDeviceId": 269,
        "_reserved1": 1,
        "inputClusters": [
          0,
          3,
          4,
          5,
          6,
          4096,
          8,
          768
        "outputClusters": [
          25,
          10
        "endpointId": 242,
        "_reserved1": 0,
        "outputClusters": [
          33
    "endpoints": {
      "1": {
        "clusters": {
          "basic": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "value": 3,
                "acl": [
                  "readable",
                  "reportable"
                "id": 1,
                "value": 65,
                  "minInterval": 1,
                  "maxInterval": 150,
                  "minChange": 0,
                  "status": "SUCCESS"
                "acl": [
                  "readable",
                  "reportable"
                "id": 2,
                "value": 0,
                "acl": [
                  "readable",
                  "reportable"
                "id": 3,
                "value": 1,
                "acl": [
                  "readable",
                  "reportable"
                "id": 4,
                "value": "_TZ3000_th6zqqy6",
                "acl": [
                  "readable",
                  "reportable"
                "id": 5,
                "name": "modelId",
                "value": "TS0505B",
                "acl": [
                  "readable",
                  "reportable"
                "id": 6,
                "name": "dateCode",
                "value": "",
                "acl": [
                  "readable",
                  "reportable"
                "id": 7,
                "value": "mains",
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 65502,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65534,
                "value": "PENDING",
                "acl": [
                  "readable",
                  "reportable"
                "id": 65504,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65505,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65506,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65507,
          "identify": {
            "attributes": [
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 0,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 1,
          "groups": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "value": {
                  "type": "Buffer",
                  "data": [
                    0
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2,
          "scenes": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "acl": [
                  "readable",
                  "reportable"
                "id": 1,
                "acl": [
                  "readable",
                  "reportable"
                "id": 2,
                "acl": [
                  "readable",
                  "reportable"
                "id": 3,
                "acl": [
                  "readable",
                  "reportable"
                "id": 4,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2,
          "onOff": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "name": "onOff",
                "value": false,
                  "minInterval": 1,
                  "status": "SUCCESS"
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2,
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 61440,
          "touchlink": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 1,
          "levelControl": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "name": "currentLevel",
                "value": 254,
                  "minInterval": 1,
                  "minChange": 1,
                  "status": "SUCCESS"
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 1,
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 15,
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 61440,
          "colorControl": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 61440,
                "acl": [
                  "readable",
                  "reportable"
                "id": 61443,
                "acl": [
                  "readable",
                  "reportable"
                "id": 61444,
                "acl": [
                  "readable",
                  "reportable"
                "id": 57344,
                "acl": [
                  "readable",
                  "reportable"
                "id": 57600,
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 61698,
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 15,
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "name": "currentHue",
                "value": 79,
                  "minInterval": 1,
                  "minChange": 1,
                  "status": "SUCCESS"
                "acl": [
                  "readable",
                  "reportable"
                "id": 1,
                "name": "currentSaturation",
                "value": 254,
                  "minInterval": 1,
                  "minChange": 1,
                  "status": "SUCCESS"
                "acl": [
                  "readable",
                  "reportable"
                "id": 3,
                "name": "currentX",
                "value": 0,
                  "minInterval": 1,
                  "minChange": 1,
                  "status": "SUCCESS"
                "acl": [
                  "readable",
                  "reportable"
                "id": 4,
                "name": "currentY",
                "value": 0,
                  "minInterval": 1,
                  "minChange": 1,
                  "status": "SUCCESS"
                "acl": [
                  "readable",
                  "reportable"
                "id": 7,
                "name": "colorTemperatureMireds",
                "value": 153,
                  "minInterval": 1,
                  "minChange": 0,
                  "status": "SUCCESS"
                "acl": [
                  "readable",
                  "reportable"
                "id": 8,
                "name": "colorMode",
                "value": "colorTemperatureMireds"
                "acl": [
                  "readable",
                  "reportable"
                "id": 16385
                "acl": [
                  "readable",
                  "reportable"
                "id": 16394,
                "name": "colorCapabilities",
                "value": {
                  "type": "Buffer",
                  "data": [
                    25,
                    0
                "acl": [
                  "readable",
                  "reportable"
                "id": 16395,
                "name": "colorTempPhysicalMinMireds",
                "value": 153
                "acl": [
                  "readable",
                  "reportable"
                "id": 16396,
                "name": "colorTempPhysicalMaxMireds",
                "value": 500
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 16397
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 16400
        "bindings": {
          "ota": {
            "attributes": [],
          "time": {
            "attributes": [],
      "242": {
        "clusters": {},
        "bindings": {}
hello johan_bendz
thank you kindly add this Door And Windows Sensor in doorwindowsensor_2 with model:
_TZ3000_yxqnffam TS0203
hank you very much for your very good work.
Sincerely
Hi!
I have a new device and I would like to include it as well. I would like asking to add 2-gang swith module with PM. Model XSH01B
How you retrieve this device info to allow me provide it?
Many thanks!
M
hello,
install your device as generic by homey and consult the zigbee in Developer Tools. (https://tools.developer.homey.app/) Find the generic module and click on Interview.
Got it! thks!!
