[APP][Pro] Tado° community app (met geofence & verw. capaciteit)
Thanks, Martin,
I have the smallest of a series, which capacity is 18kWh nominal. I can’t find anything in the manual/docs it has been adjusted to anything lower, but I also can’t imagine it is running at a percentage of that capacity. I’m not in a “tiny-house” :grin:
Apologies Peter, i have explained it not clear enough :wink: , it is not a default for the CV to be found in the manual. Ususally it can be set through a menu when installing the CV.
e.g. if your house is 200 cubic meter that needs to be heated to 19/20, the power needed (as an example) is 200*63 watts ~ 13kWh for your CV. So the installer might have set your device to less than the 18kWh through the menu to have it run at needed capacity.
Thanks, it was partly clear, Martin. But I expected it to be written down in the books that go with the heater, by the installer. But that was last century :rofl:
I’ve learned the high power values are only needed for showering and such.
So, I found out my heater is by default (factory) set to 70% of 17.8kW = 12,5kW
So I checked it, and yes, untouched, it still is 70% … installer even didn’t bother, or ‘got instructions’ not to touch it.
I just changed it to 60%, so now the power it’s about 10.7kW.
I have around 75m³ of actually heated rooms
Gonna tune it further after the freeze outdoors.
Ik heb geen tado apparaten, kan ik nog steeds de geofence in de app gebruiken en hoe stel ik die in?
Nee, dat kan niet, minimaal Tado themostaat nodig + aanvullend abonnement als je wilt dat het automatische gaat.
Is er iemand die meerdere tado bridges gebruikt (meerdere huizen of aparte setup in zelfde huis)?
Repair is eigenlijk alleen van belang indien het device door bv authorisatie niet online komt. Indien Tado offline is en de devices niet bereikbaar, dan zouden die vanzelf weer beschikbaar moeten komen indien Tado weer bereikbaar is via het netwerk.
Ik heb in de komende release wel een “repair” functie toegevoegd voor als je wel zou willen repareren nav authorisatieissues.
Maar in de nieuwe versie zal dat ook mogelijk zijn op het “home” device. De app zal dan meerdere homes tegelijk supporten.
Hallo allemaal,
Ik was altijd zeer te spreken over de geofance van de oude tado app. Ik zie nu dat er een nieuw app Tadozone is, maar die kan ik niet vinden in de app store van Homey. Ik zie hem wel in deze app store https://store.homey.community/, maar dan is die niet te downloden? Hoe werkt dat en is dat wel veilig die andere app story?
Ja hoor, da’s zeker veilig.
De Community App Store is juist een enorme aanvulling op de officiële Homey app store.
Hier vind je meer info:
Als je de de app vanuit de Community Store via je pc op je Homey installeert kun je vervolgens de apps ook meteen vanaf de site naar je Homey downloaden.
En via de App Version Checker app zie je vanzelf of er een nieuwe versie is
Bedankt Henk,
Door de feestdagen ben ik laat met mijn reactie.
Ik heb vervolgens de volgende stappen gedaan, maar het stopt al bij punt 2. Ik krijg helemaal geen code:
  1. Ga naar https://store.homey.community/ en klik hier rechtsboven in het ronde groene vlak met witte streepjes. Klik hier op het vierkantje met het pijltje en log hier in bij Athom.
  2. Wanneer je dit doet zal de Homey vragen of hij toegang mag tot de CLI app, dit moet je toestaan. Vervolgens krijg je een code die je moet kopiëren.
  3. Nu kan je deze code invullen in de community store onder: ‘ plak hier de autorisatie code’.
  4. Als deze code is ingevuld zal de community store contact maken met de Homey’s binnen je Athom account.
  5. Nu klik je vervolgens wederom rechtsboven op het groene ronde vlak en kies nu optie met drie ronde ringen (Homey Community Store). Hier wordt gevraagd om een bestand te downloaden, kies hierbij uiteraard het besturingssysteem waarop je laptop/pc werkt.
  6. Wanneer het bovenstaande stappenplan is voldaan en het bestand is gedownload/geïnstalleerd heb je de mogelijkheid om app de te gebruiken uit de community store!
Weet jij Henk wat ik niet juist doe?
Gebruik Firefox.
Onderstaande how-to is wel in 't Engels, klik / tik op het v teken rechts om de het in zijn geheel te zien en lezen:
Bovendien helpt het als je even post wat je wèl ziet bij punt 2 als @Peter_Kawa’s tip niet helpt.
Maar doe dat vooral even in het Community Store topic. Dit is geen specifiek Tado gerelateerde vraag
Zie:
Switched to Tado system (because of Tadozones). :wink:
But run into an error,
After installation:
  • I do see the app installed on the Homey mobile app
  • but on the web version it is not visible (cannot install new devices)
  • when i add device (thermostat) via mobile, it asks me to login (so app is working)
  • but after it does not show a list of devices
    Error: “tado.devices.forEach is not a function”
  • When adding Heating Circuit
    error : “Cannot read properties of indefined ®ading ‘forEach’)”
edit 1:Via Tado app, the devices are shown, can be added.
edit 2: removed and re-installing, did not help
Hi Bart,
Installing / adding new tadoZones devices using web app works fine.
I think you’ll need to empty the browser’s cache and refresh the page, CTRL+SHIFT+R should work.
Else, try with a private tab / window of your browser.
Hi Peter, thanks for your reply/advice
But that does not make any difference. On incognito, searching for Tado does not bring up tadoZones
while it does on mobile. The bigger issue is not being able to add device on mobile (error message).
I found the log on App setings, which shows multiple red lines, but i see no option to copy or export the log
Ik zie een aantal maal “unauthorized” in de log, dat betekent dat je nog niet bent ingelogd.
Upcoming 4.2.0 Release.
  1. Multi Tado Homes/Users/Bridges implementation
  2. Introduction of home device (not needed if single home) and heating circuit device (if you have multiple heating circuits in a home).
  3. Usage of tado-node-client from Matt
  4. Add of action flowcard to get energy forecast for max of 14 days ahead. Based on weather data.
  5. Add of action flowcard to add current energyIQ tariff.
  6. Single tado climate control code
  7. Get possible min and max temperature options from tado definitions
  8. Get Fan capabilities from tado device capabilities (speed, level, swing V and H)
Needs to run stable for next week, then it will be released.
Hey Martin,
Thanks and nice to see the growing possibilities.
I don´t know about the gas counter, it should report this day’s usage, but I use a few m3 per day atm. Any idea?
It looks like it shows the total usage since the function became available?
The EnergyIQ gets updated daily:
Better check again with release of 5.2 , been fidling around with this a lot…
Hi @Martin_Verbeek
I removed the app and re-installed again from HCS (version 3.0.5) . But see the same behaviour. After installation:
Above you mention version 5.2 is released. Where do i find this version? Again in HCS i only see version 3.05
