[APP][Pro] Systemair
I second this. Fireplace mode would be great :slight_smile:
How you get the right ip adress?
Hi!
I can’t make this work. When I logg into save connect, it works fine. But when I try to add it to homey I get the «Error: Times out after 30000ms. Do I need to disconnect my save account? Eny tips?
Did you find a solution to this problem , struggling with The same problem.
Nope, did not. I also have the orginale save connect 2.0. Can’t get this to work either
Hi! I also seem to have some issues with connecting the System Air AIM. I also get the “Error: Time out after 30000ms”. It was working fine with previous versions, but I had to change IP in the configuration a few times, while now I am not able to connect via Homey. I can connect directly to the device. It is on the same network as Homey. Any ideas?
Hi! How do you change the ip adress?
I got the connection to work once, but got an error. Is there a TCP converter mode? How do I turn it on?
Hi! I got the save connect 2.0 into Homey, but its not updating. But its one step closer. Try typing inn 192.186.4.1 and not 192.168.4.1
I got it working by logging onto my router config to check what ip adress it gave The save Connect module ( in my case 192.168.50.46) and not The ip adress located on The save Connect box.
Im also having trouble integrating the SaveConnect2.0 into the Homey app. I have tried more or less everything above, also the different IP adresses. And I either get “Timeout after 30000ms” - using the router ip, and “Connection is refused. Check that the IAM is set in Modbus TCP converter Mode” when using the ip on the SaveConnect2.0-box itself. Also wondering if to use Systemair IAM Modbus" or Systemair Save Connect http" when trying to integrate
Any leads of where to go next? Understood that the save2.0 does not support tcp mode, yet? Thanks in advance for any help.
Did you do anything more than changing the ip?
I managed to get the connect2.0 into homey, and changed the ip under the “Systemair IAM Modbus” → Advanced Settings → Ip. But even so, changing the parameters of the “Systemair IAM Modbus” in Homey does not affect the Systemair app or the ventilation aggregate. Anything I’m missing here?
Any news from SystemAir on this?
Hey guys,
I can represent Systemair for residential air handling units integration into home automation systems, keep in mind, this is personal effort and company shall not be entitled to what ever I say or promise.
Save Connect 2.0 does not support Modbus TCP/IP, there is no such service built in in the device. However, what you could use is Modbus RTU/TCP IP gateway. This device is amongst our accessories portfolio for residential air handling units.
Now, regarding IP address on the Save Connect box, this IP is used when SaveConnect 2.0 is in access point mode, otherwise home router will assign IP adress to your SaveConnect 2.0. When SaveConnect 2.0 device is in access point mode use your Wi-Fi enabled device to connect to streammed Wi-Fi network SSID ‘SaveConnect’, use provided IP to access web app which is built in the SaveConnect 2.0 device.
Hi
Would it be possible to have the heat recovery percentage visible?
(Heat exchanger AO state, addr 14103)
One comment, request:
For temperature regulating we use the “extract air” temperature for controlling the regen/heating/cooling.
When I have this set - the temperature visible in the Homey-App is still the INTAKE temperature measured. The result is that the App will always be in the “orange” heating mode - meaning that it will add more heat.
see the pictures:
Is it possible to add a function to turn off the ventilation as well? :slight_smile:
