I pressed the send log button now, around 21:50
I cant find where to send PM? Maybe new users cant?
Did you get a log on your email?
Yes, I have the log and will have a look soon.
Thanks.
Could there be a problem using space in the name for the screens, and i also have a Norwegians letter Ă i a name. Maybe that messens it up.
I will try change it.
Edit: that didnt change anything.
No, the app doesnât use the name. There are unique idâs that the app uses.
Itâs probably just a device that not supported yet in which case I will add it in.
The log shows you have âio:AwningValanceIOComponentâ motors so you should be able to add them with the âAwning / Pergola (io)â device in the app.
Thank you so much. Homey found them immediately.
Having issues adding my Velux blinds againâŚ
I had some issues with my blinds so I had to reset all remotes for the blinds and add them again. I started with adding 1 blind to the Connexoon box, and that worked smoothly:
Nest, I deleted the 3 blinds in the Homey Somfy App. Now I am trying to add them again. Unfortunately I do see the three Velux windows and can add these again (that is not needed) but canât seem to find the new added blind.
Anyone a clue how to re-add it again?
I am using App v3.0.30
Is this a new blind that has not been in Homey before?
Just wondering if it is a different type that the app doesnât know about yet.
If it is then can you send me the device log as shown in the first post so I can add it to the app?
Yes, two new blinds Adiaan. One even has a different color of the housing.
I will send the logs! Thanks.
BTW
I only added one blind to Connexoon yet. So the other two blinds will not be seen. Will try that later today / tomorrow. Bit in a rush
If they are they the same as the one in the log then itâs not a problem.
Update
Itâs working now! I added the 2 remaining screens to Connexoon and they now show in Homey too!
I guess I selected the wrong screens, initiallyâŚ
Thanks again for the swift reply and help Adrian!
Iâm sorry for my late reply. After some try, I have delete the remote of my ToHoma an pairing directly of the dimmer (most reactivity for light on/off).
If youâre interested by the log, send me a private message. I can re-appair the device and send log.
