In the new version I have added an option to the settings of each device to reverse the directions.
The confusion is that Homey uses up / down but Tahoma uses open / close. For window covers up is open and down is closed. But for awnings it seems up is closed and down is open.
There is a new test version https://homey.app/a/com.somfy.tahoma/test/
This fixes a potential issue with flows failing when the access token expires.
It also has option for each type of cover to change the direction of up / down versus open / close. The settings are available in each device by clicking on the cog in the top right corner, select Advanced Settings and toggle the option as required.
The setting for Invert Up / Down changes the direction of the Up / Stop / Down buttons (and the Up / Down flow cards).
The setting for Invert Position changes the direction of the slider and the 0 to 100% value of the flow cards.
hi Adrian. thanks for the update and great that there is new development. It did, however, ensure that when it rains, the sun blinds are open instead of closed. but that i resolved it. I have a question about the icons. these respond when you press them briefly. that is beautiful! only one icon is disabled and the other active. while in both cases the shading is closed.
Could you send me the Device Log (Apps - Somfy Tahoma & Connexoon - Configure App - Device Log tab) while the shades are in this state.
Also let me know if you have set any of the Invert options.
Thanks.
Thanks for developing this.
I have an error 401 when trying to log in. The credentials are correct. I also changed the password to see if that would fix it.
Using a homey and a connexoon io box. The connexoon works with my shutters.
I have a report from another user with the same issue but they have a Tahoma hub.
Could you login to your account on the Internet (so you can see your shutters) and let me know what the URL is in the address bar. I just want to confirm the first section so remove the end, from where it shows your user name. It should be something like https://www.tahomalink.com/enduser-mobile-web/enduserAPI
I have a suspicion that Somfy might have changed it for new accounts or different regions.
I have a connexoon io (received yesterday, so its still searching a bit). I found no way to use a website that finds my shutters, and on the tahomasite i cant login with my account.
I have published a test version in the Homey Community Store (2.0.4) https://store.homey.community/app/com.somfy.tahoma
I am waiting for the current test version (2.0.3) in the Athom store to be moved to stable, so Iām not able to publish it to there yet.
This version has an option in the app configuration to select alternative server address. This might help with the connexoon users that are having issues logging in.
I have reorganised the log in procedure, to allow for the server change over, which also stops the app form retrying bad credentials that might be locking out the account for this app. I think I locked out my account while testing with bad credentials as I had to wait for about an hour before my good credentials would work again.
Thanks for your efforts and time youāve put into this. I tried all 3 twice(first alternatve, then connexoon rts and afterthat default) but received āerror authentication failedā every time.
I tried to send you the errorlog, but received also an error
Just out of interest, do you have any extended characters in your username or password?
If so could you try a password that just has 0 to 9, a to Z, - and _ in it. Itās a long shot but Iām trying to think of anything that would be different from one that works.
The error message when you send the log suggests a DNS error as it has tried to use the loop back address. Iām not sure if that is related to the other problem as I have seen that before in another app. That seems to be related to installing from the HCS.
I have posted version 2.0.5 in the community store. I have implemented the OAuth login method in this version as it seems Somfy might have switched over to that for new Connexoon accounts.
The option can be turned on in the app configuration screen where you find a check box just underneath the server selection.
I recommend starting off with the default server and the new OAuth ticked. Fingers crossed.
Now I need to get a couple of hours sleep before work
Thanks for your effort Adrian.
with 2.05 I can enter the credentials, and it says login succesfull.
But when I add a new device (somfy shutter io) I get the message login failed, after it searches for devices.
I used default connection url, new oauth on and off.
