[APP][Pro] SMA Solar devices
192.168.0.0 is almost impossible to be the correct IP for a regular network client.
With (Android) tools like Fing, Network Scanner, Ping Tools, you can discover the IP addresses of your network devices.
Yeah 192.169.0 0 always standing before you write something.
I tried the right ip-address but it wont work as i write.
Have the inverted connected with Ethernet.
I can ping the inverter and get good results,bit still it wont work.
Are Modbus and TCP-Server activated?
Yes,
When the app doesnt find the inverter there are typically two things that are at fault
  1. Modbus TCP not enabled, as @Martin_Ahlert suggested
  2. Something in the network that prevents Homey from communicating with the inverter.
Given that the app isn’t able to find the inverter automatically it tells me UDP multicast from the inverter doesnt reach your homey, e.g. different VLANs or similar.
I have myself a dreammachine pro and the STP 25000TL - 30 inverter and it works here.
Thanks for the info.
Good to know that my almost same setup working somewhere else.
Then I will continue to investigate what the problem is.
