# \[App\]\[Pro\] PaperTrails Log - Advanced Logging and SysLog
**URL:** <https://community.homey.app/t/app-pro-papertrails-log-advanced-logging-and-syslog/40>\
**Category:** Apps\
**Tags:** app, official, tools\
**Created:** [August 14, 2018, 9:50pm UTC](https://community.homey.app/t/app-pro-papertrails-log-advanced-logging-and-syslog/40 "2018-08-14T21:50:57Z")\
**Showing post:** 67
**Post date:** [January 18, 2021, 9:39pm UTC](https://community.homey.app/t/app-pro-papertrails-log-advanced-logging-and-syslog/40/67 "2021-01-18T21:39:51Z")
@Henk_Renting@Bob_Oosterhof
As mentioned before,
> [@Dijker](#):
> Moved the following to a Web App Dashboard Behind the Community HomeyBackup Web App: [https://homeybackup.web.app/login/](https://homeybackup.web.app/login/) (as it is not possible from Homey V2 anymore)
> - Added Magic!
> - Automatic Adding & Removing Logging to All Flows with a Prefix.
> - Migrating Flows from Simple Log.
Tested it last week with Homey v5 and that still works, (Adding and Removing Papertrails to All Flows.) the only point is it is pretty prone to “failures”
Homey doesn’t Accept “Broken” flows anymore. (Since v2.0)
So if you have fe 30 Flows but the 3rd flow is broken it will only update the first 2 flows.
Please check your Homey fitst for broken flows and fix or remove them.
Find a Help here:
> [@Developer Web API Playground - Notes of geeky oneliners](https://community.homey.app/t/developer-web-api-playground-notes-of-geeky-oneliners/24392):
> For the developers and geeks that want to investigate their Homey’s config. Run from [Homey Developer Tools](https://developer.athom.com/tools/api-playground) I write this to remember what I did but also to inspire others that I know are better JS developer that can do more magic. (and hope they share to inspire!) WARNING: Be Careful! you can ruïne your config by deleting the wrong objects from there! Only use it if you know what you are doing ! // Get Trigger counts for Flows Homey.flow.getFlows().then(f =\> Object.values(f).reduce((r,b)=\>Obj…
Due to many personal thing I didn’t take time to update the App (Both Papertrails as the Homey Community Backup App with Papertrails Dashboard.)
Maybe if time permits I will but for now you have to do it with this.
_[View the full topic](https://community.homey.app/t/app-pro-papertrails-log-advanced-logging-and-syslog/40)._
