# \[APP\]\[Pro\] Opel Ampera-e (WiCAN) - battery and charging data via a WiCAN dongle
**URL:** <https://community.homey.app/t/app-pro-opel-ampera-e-wican-battery-and-charging-data-via-a-wican-dongle/160353>\
**Category:** Apps\
**Created:** [October 4, 2026, 12:20pm UTC](https://community.homey.app/t/app-pro-opel-ampera-e-wican-battery-and-charging-data-via-a-wican-dongle/160353 "2026-10-04T12:20:41Z")\
**Posts on this page:** 1\
**Page:** 1
<div class="post-metadata">
**Author:** ![Ruud\_Schellekens](https://sea1.discourse-cdn.com/flex025/user_avatar/community.homey.app/ruud_schellekens/32/79224_2.png) [@Ruud\_Schellekens](https://community.homey.app/u/Ruud_Schellekens)\
**Post date:** [October 4, 2026, 12:20pm UTC](https://community.homey.app/t/app-pro-opel-ampera-e-wican-battery-and-charging-data-via-a-wican-dongle/160353/1 "2026-10-04T12:20:41Z")
</div>
## Opel Ampera-e (WiCAN)
Bring your **Opel Ampera-e / Chevrolet Bolt EV** into Homey with a **WiCAN or WiCAN Pro** OBD-II dongle. The dongle reads the car’s battery data and sends it over MQTT; this app turns it into a Homey device.
**App Store:** [https://homey.app/a/info.schellekens.amperae](https://homey.app/a/info.schellekens.amperae)
### What you get
- State of charge, charging power, AC charging voltage and current
- Charging state (charging / plugged in / unplugged)
- Battery and outdoor temperature
- Minimum and maximum cell voltage
- Usable battery capacity (kWh), battery resistance (mΩ) and charge cycles
- Estimated range, based on SOC × capacity and your own average consumption (kWh/100 km)
The app is **read-only** : it never sends anything to the car.
### No separate broker needed
The app has a **built-in MQTT broker**. The WiCAN publishes straight to your Homey, so you don’t need the MQTT Broker app or any other software. Already running a broker? You can connect to that instead.
### Setup in Homey
1. Install the app and add a device **Opel Ampera-e**.
2. Choose **Built-in** broker, set a username (e.g. `wican`), a password and a topic (e.g. `ampera-e/telemetry`).
3. Press **Check port**. The pair screen shows the address to enter in the WiCAN.
If another MQTT broker app is running on port 1883, switch it off first (or pick another port).
### Tested WiCAN Pro settings (firmware 4.50)
**Settings → CAN / MQTT**
| Setting | Value |
| Protocol | AutoPID |
| MQTT | Enable |
| MQTT URL | your Homey’s IP address |
| MQTT Port | 1883 |
| Security | None (MQTT) |
| MQTT User / Pass | same as in Homey |
**Automate**
| Setting | Value |
| Vehicle Specific PIDs | Enable |
| Vehicle Model | Opel: Ampere-E 2019 (gives SOC, BATT\_TEMP, AC\_C\_C, AC\_C\_V) |
| Destination | one **MQTT Topic** destination, same topic as in Homey, cycle 5000 ms |
| Low-Voltage Behavior | Pause PID polling only (Custom Voltage), 12 V |
**Automate → Custom PIDs** (init `ATSH7E4`, names must match exactly)
| Name | PID | Expression | Unit |
| CHARGE\_CYCLES | 2243A51 | ((B4\*256)+B5) | cycles |
| HV\_CAPACITY | 2241A31 | ((B4\*256)+B5)\*0.032 | kWh |
| MIN\_CELL\_V | 2243291 | ((B4\*256)+B5)/1666.666 | V |
| MAX\_CELL\_V | 22432B1 | ((B4\*256)+B5)/1666.666 | V |
| BATT\_RESISTANCE | 2240E91 | [B4:B5]/2 | mΩ |
| AMBIENT\_TEMPERATURE | 2200461 | B4-40 | °C |
**Power Saving:** Sleep Mode Enable, 13.1 V, 5 min. This protects the 12V battery.
### Troubleshooting
Open the device settings and look at **Broker status** :
- _Broker started, waiting for WiCAN_: the dongle isn’t connecting. The car is probably asleep (the WiCAN turns off its Wi-Fi then), or the MQTT URL in the WiCAN is wrong.
- _Login rejected_: username or password differs between WiCAN and Homey.
- _Last message on “…”_: data is arriving. Check that the topic matches the one in Homey.
While the car sleeps, Homey keeps the last known values. Data comes in again as soon as you drive or charge.
### Notes
- Charging power is a separate capability (not `measure_power`), so Homey Energy doesn’t count it twice next to your charger.
- The range is an estimate. Set your own consumption in the device settings for a better figure.
- Tested on my own Ampera-e (2017) with a WiCAN Pro.
This app is not affiliated with Opel, Chevrolet or MeatPi Electronics.
Questions, bugs or other Bolt/Ampera-e PIDs that work for you? Post them here!
