Yea, I’m too quick hitting ‘Save edit’ and you’re just … quick
Settings error is fixed!
Thanks
New app update (live: 2.5.1):
- NEW: Red Green Yellow - screensavers
- FIX: error on settings page
Everything is mixed up (version 2.5.1) when I select a few screen savers. The selected screensavers are not active, but some non selected are active.
Rebooting / reinstall doesn’t solve the problem.
I just cli installed 2.4.4 and that version works ok. I’ll install latest version and send report.
Rapport is: 94137d93-764a-4a60-8de9-dca6ebf6a7ee
Thx Will check!
Can you go to this page and execute this command and share the result with me? https://tools.developer.homey.app/tools/api-playground
Homey.apps.getAppSettings({id: ‘openmindnl.ledcollection’})
New app update (test: 2.5.4):
- FIX: issue with saving screensavers
- FIX: saving screensavers wrong index
Probably this fixes the issue @HansieNL
This fixes the wrong saving issue
New app update (live: 2.5.4):
Is it possible to store what screensaver is running and the restore that?
Hey @jonorland
Don’t think so. I made some flows with pre-set screensavers, so I can trigger that flow. But there’s no way to get the current sceensaver or put it in a variable
Thanks for the extensive selection of screensavers @martijnpoppen !
Maybe a strange request but it would be really cool if there was a “breathing exercise” screensaver with configurable parameters for:
- seconds breathing in
- seconds holding breath (might be 0s)
- seconds breathing out
- seconds no breath (might be 0s)
- (perhaps a configurable color?)
It would make Homey into a mindfullness hub and mostly increase the wife-acceptance-factor @home
Thanks for considering and keep up the great work
Hey @Qx5
I like that idea. But maybe it will fit better in the LedItBe app.
I also maintain that one. Will check!
Awesome! Let me know if I can help by testing or something else
New app update (test: 3.0.0):
- BREAK: update to Homey SDK 3
This will update the LED-Ring collection app to Homey SDK 3. This prevents the app from being hidden in the app store from 01-01-2023.
However this will not mean that this app is available for the new Homey Pro 2023.
Unfortunately the ledring of the new Homey Pro 2023 is not configurable.
This app will stay and will be available only for the White Homey ball.
Great Martijn!
Then people kan still use it on the Satellite Homeys!
Is there any change i can alter the sourceode when you are done, add some api calls to is, so i can use it directly from the Himiny (temp name) Controller?
Hey @Arie_J_Godschalk ,
Yeah sure. Would be nice
Let me know if you need something or we discuss on slack
@Arie_J_Godschalk I’ll update this soon too. So might be interesting as well → [APP][PRO] - Led It Be
