# \[APP\]\[Pro\] Eastron - Advanced Energy Monitoring with DIN Rail Meters over Modbus TCP
**URL:** <https://community.homey.app/t/app-pro-eastron-advanced-energy-monitoring-with-din-rail-meters-over-modbus-tcp/147339>\
**Category:** Apps\
**Tags:** app, energy, smart-meter, homey-pro, homey-energy\
**Created:** [December 19, 2025, 1:51pm UTC](https://community.homey.app/t/app-pro-eastron-advanced-energy-monitoring-with-din-rail-meters-over-modbus-tcp/147339 "2025-12-19T13:51:14Z")\
**Showing post:** 22
**Post date:** [March 29, 2026, 7:02am UTC](https://community.homey.app/t/app-pro-eastron-advanced-energy-monitoring-with-din-rail-meters-over-modbus-tcp/147339/22 "2026-03-29T07:02:49Z")
Not sure on what exact settings you need for the Eastrom SDM630, but the baud rate seems a bit high, I suggest starting with 9600 and see what happens.
Also, I see port 26 and 23 used, did you set those values? I would expect to see 502 there.
These are my settings for a similar waveshare device connected to a Growatt inverter:
> [@\[APP\]\[Pro\] SolarEdge + Growatt TCP modbus](https://community.homey.app/t/app-pro-solaredge-growatt-tcp-modbus/45487/1579):
> So, took the plunge and ordered the [Waveshare RS485 to PoE Ethernet Module](https://www.tinytronics.nl/en/communication-and-signals/serial/rs-485/waveshare-industrial-serial-server-rs485-to-poe-ethernet-module) and had some time today to hook it up and configure it. I connected both my Growatt 3000TL3-S inverters to the module and after some fiddling on the Inverters (Giving each a unique ID) and in the module’s settings I got it working! Here the settings that work for me: I made the following changes that differ with de module’s default settings: Network Settings Device Port, set it to 502 IP Mode, switched it …
(Suggestion: set the IP type to DHCP and add a reservation to your router if possible)
_[View the full topic](https://community.homey.app/t/app-pro-eastron-advanced-energy-monitoring-with-din-rail-meters-over-modbus-tcp/147339)._
