[APP][Pro&Cloud] Shelly
Yes, that’s what you said, did you read my post? It was a advice to check if you have the latest fw. Because that solves some low reception issues with multiple ap. That could help to prevent this from occurring in the future.
Yes all was at latest level
Met vriendelijke groet,
René van Duijkeren
Hey all,
I’m running some RGBW (GU10) lamps in my bathroom and having some issue with it. I’m running a flow where the lamps turn amber-like from 20:00 to 06:00. I use a flow that sets the set the hue for this. During the day I want bright white light, and the only way to get proper colour/brightness in my opinion is to use the set the temperature card.
However, when Homey has executed the temperature card flow it is not able anymore to switch back to the amber colour. It looks like the lamps are “stuck” in white colour mode. I’m also not able to manually select a different colour through Homey. I have to go into the Shelly app and set the lamps back to “colour” mode to be able to select colours (which then also starts working again through the Homey app).
Anyone experiencing the same issue perhaps or has an idea on how to fix this?
Cheers!
Sounds like a bug where it does not switch between color and temperature mode. I might need to explicitly tell the light to do this. I’ll look into it.
I just pushed a new release to the test channel of the app store (see the link below). The release does not contain any new functionality but a lot of code has been rewritten to make it easier for me to maintain the app. I’m looking for people that are willing to test this version before I publish it to the stable channel. You only need to do a smoke test and see if the device updates it’s capabilities as expected and you can switch back to the stable version from the app store afterwards without issues. If there is something wrong with the test version please let me know here and send me a app diagnostics report. Thanx.
v3.0.29 - 2021-03-27
  • Code improvements for easier maintenance
  • Small fix for switching between color modes of the Shelly Bulb
@Phuturist I’m accidentally still on beta. Now my flows with button press action events don’t work with all my Shelly devices. How can I revert back to the stable version?
First let me know what devices dont work and send me a diagnostics report. After that I will tell you … :stuck_out_tongue:
You can just install the regular version from the app store.
Thanks for the response, but because of an angry wife I installed the previous version rather quick so I wasn’t able to make a report, sorry…
However, on versión 3.0.28, my devices show a red exclamation mark once in a while and aren’t reachable… But that disappears after a few seconds, and a couple of minutes later, it’s back. Any idea how this can happen?
It means Homey cant reach the Shelly devices over HTTP API but the devices can report to Shelly using CoAP broadcasts. Send me a diagnostic report to see if it’s related to network issues.
Oké thanks, the Shelly app works when homey gives error on ehostunreach
Something happened with my 3EM device after latest update It worked before no problems. Red triangle randomly appears on 2nd or 3rd phase or both, approx. once per minute. Device itself is available with web and there is no missing pings to device.
Can you send me a diagnostic report from the app settings.
I’ve got some i3’s that lost the action card and all the flows that depend on it. When I change to input on/off they are still reachable. So device is not lost but the action card is gone.
What action card is gone? I did not touch any action card code in the latest release.
Also have this problem, after updating to 3.0.29
Hello, i have the same problem with the 3em in 3.0.29
I’m getting this since the latest update
Short and longpush on the second input are ‘undefined’ si no longer work. On first input they still report correctly f.e. shortpush_1
Its the same with dimmer1 and dimmer2 type Shelly
Thanx for all the feedback. I’ll push some fixes in the next hour. It seems some of you are not even aware you have the test version installed (and thus run the risk you run into breaking changes). You can install the stable version by installing the app through the app store.
v3.0.30 - 2021-03-27 - TEST
Seems to be working again after the fix.
All the devices under the tab App were there but when choosing an action there were no devices available
