# \[APP\]\[Pro\] ClimaWise – Smart heating & cooling, room by room (heat pumps, radiators, towel dryers)
**URL:** <https://community.homey.app/t/app-pro-climawise-smart-heating-cooling-room-by-room-heat-pumps-radiators-towel-dryers/162417>\
**Category:** Apps\
**Created:** [November 18, 2026, 8:49pm UTC](https://community.homey.app/t/app-pro-climawise-smart-heating-cooling-room-by-room-heat-pumps-radiators-towel-dryers/162417 "2026-11-18T20:49:44Z")\
**Posts on this page:** 9\
**Page:** 1
<div class="post-metadata">
**Author:** ![Roy\_PEDRINIS](https://sea1.discourse-cdn.com/flex025/user_avatar/community.homey.app/roy_pedrinis/32/183624_2.png) [@Roy\_PEDRINIS](https://community.homey.app/u/Roy_PEDRINIS)\
**Post date:** [November 18, 2026, 8:49pm UTC](https://community.homey.app/t/app-pro-climawise-smart-heating-cooling-room-by-room-heat-pumps-radiators-towel-dryers/162417/1 "2026-11-18T20:49:44Z")
</div>
Hi everyone 👋
I’d like to introduce **ClimaWise** , a Homey app that manages heating and air conditioning room by room. It’s part of my “Wise” family (ShadeWise, AirWise, PoolWise, GardenWise).
[screenshot: the ClimaWise house widget]
### What it does
- **Rooms, not devices** : group the devices of a room (split / heat pump, thermostat, radiator on pilot wire, towel dryer, relay) and pick a real room sensor. ClimaWise corrects the split’s own sensor with it.
- **Comfort profiles and weekly schedules** : Comfort, Eco, Night, Away, Frost protection, with your own setpoints.
- **Automatic season** : based on the months, adjusted by the outdoor temperature and the forecast. Never uses the devices’ “auto” mode: it’s always heat or cool.
- **Gentle on heat pumps** : at setpoint it lowers the target instead of switching off, and keeps at least 20 min between two starts. It also limits cloud commands (MELCloud, Tado, Heatzy…) and doesn’t mistake a slow cloud update for a manual change.
- **Windows and doors** : pauses after a few minutes, resumes when closed. The door rule can be limited to a time window. Built-in open-window detection (Tado, Heatzy) is respected.
- **Presence and vacation** : Away when nobody is home, Vacation for long absences.
- **Learned pre-heating** : rooms are at temperature on time.
- **Boost** per room (e.g. bathroom 24 °C for 30 min from a button).
- **Manual changes respected** until the next schedule slot.
- **Frost guard** per room (“never below 7 °C”).
### Energy (all optional, off by default)
- Off-peak hours and **EDF Tempo** (France): pre-heat in off-peak, −1 °C on red days, heat stored the night before.
- **Solar surplus** : a small boost when your panels export.
- **Forecast sun** : less morning pre-heating in sunny rooms.
- **Load shedding** : pauses towel dryers and radiators first when the house gets close to your contract power.
- **Weekly report** : kWh per room and comparison at equal weather.
### In Homey
- One **virtual thermostat per room** , so you can use the app, dashboards and voice.
- A **House device** with season mode, presence mode and “Eco 2 h / Back to schedule” buttons.
- **4 dashboard widgets** :
  - House: animated scene following the live weather; the heat-pump fan spins when a split runs;
  - Rooms;
  - Room: setpoint and Boost;
  - Energy: today, last 7 days, by room, Tempo.
- Insights charts, many Flow cards, and Homey’s own thermostat cards.
[screenshots: settings page · Room widget · Energy widget]
### Safe start
The app is **off by default**. While it’s off it runs in **trial mode** : each room shows what ClimaWise _would_ do, without touching any device. A wizard finds your rooms, devices and sensors.
### Wise apps link (optional)
If you also use ShadeWise, AirWise, PoolWise or GardenWise, they can share:
- vacation,
- the solar surplus,
- outdoor readings,
- Tempo colours,
- the heatwave / cold snap plan,
- a single daily summary.
Each app decides on its own; nothing is controlled remotely.
### Languages
English, French, German, Dutch.
### Install
[test version link / App Store link]
Tested at home with:
- Mitsubishi splits (MELCloud),
- a Tado Smart AC,
- Heatzy towel dryers,
- Netatmo and Aqara sensors.
It should work with any brand that exposes a thermostat, a pilot-wire mode or an on/off.
Feedback, bug reports and ideas are very welcome. Please mention your devices, it helps a lot! 🙏
**Author:** ![Henk\_Renting](https://sea1.discourse-cdn.com/flex025/user_avatar/community.homey.app/henk_renting/32/87634_2.png) [@Henk\_Renting](https://community.homey.app/u/Henk_Renting)\
**Post date:** [November 18, 2026, 10:06pm UTC](https://community.homey.app/t/app-pro-climawise-smart-heating-cooling-room-by-room-heat-pumps-radiators-towel-dryers/162417/2 "2026-11-18T22:06:41Z")
</div>
This sounds very promising!
I already missed an app that would make my (Mitsubishi Heavy Industry) airco and Tado themostat and trv’s work together…
Curious if this app will fill that gap! 🙂
Does the app simply put both to work when heating or does it also respect the airco & central heating strongest points and act accordingly? Like heating up a room, keeping it at a certain level, etc?
Perhaps also considering gas- and electricity prices?
Very much looking for an intelligent system that creates the best mix between comfort and cost…
Looking forward to the test version! 🙂
**Author:** ![SingKT](https://sea1.discourse-cdn.com/flex025/user_avatar/community.homey.app/singkt/32/173226_2.png) [@SingKT](https://community.homey.app/u/SingKT)\
**Post date:** [November 19, 2026, 9:40am UTC](https://community.homey.app/t/app-pro-climawise-smart-heating-cooling-room-by-room-heat-pumps-radiators-towel-dryers/162417/3 "2026-11-19T09:40:35Z")
</div>
You are hopefully going to provide links to your app soon.
**Post date:** [November 19, 2026, 4:25pm UTC](https://community.homey.app/t/app-pro-climawise-smart-heating-cooling-room-by-room-heat-pumps-radiators-towel-dryers/162417/4 "2026-11-19T16:25:07Z")
</div>
The link is:
> **[ClimaWise | Homey](https://homey.app/en-nl/app/com.roypedrinis.climawise/test/)**
> Comfortable rooms, gentle heat pumps and smarter energy use.
@Roy_PEDRINIS: the schemes at the bottom of this page are not translated.. 😊
 ![1000043353](https://us1.discourse-cdn.com/flex025/uploads/athom/original/3X/1/a/1ae5c94362c81120090e877d3ddaafc229f0546f.jpeg)
**Post date:** [November 20, 2026, 8:08am UTC](https://community.homey.app/t/app-pro-climawise-smart-heating-cooling-room-by-room-heat-pumps-radiators-towel-dryers/162417/5 "2026-11-20T08:08:25Z")
</div>
Thanks for the feedback; I’ll make some changes.
**Author:** ![Darren\_McCarthy](https://sea1.discourse-cdn.com/flex025/user_avatar/community.homey.app/darren_mccarthy/32/169647_2.png) [@Darren\_McCarthy](https://community.homey.app/u/Darren_McCarthy)\
**Post date:** [November 21, 2026, 12:56pm UTC](https://community.homey.app/t/app-pro-climawise-smart-heating-cooling-room-by-room-heat-pumps-radiators-towel-dryers/162417/6 "2026-11-21T12:56:10Z")
</div>
How does it determine the heat pump? Can’t see where I put that in. My Daikin is listed in Homey correctly.
Thanks,
Darren
**Author:** ![ChrisBoer](https://sea1.discourse-cdn.com/flex025/user_avatar/community.homey.app/chrisboer/32/1252_2.png) [@ChrisBoer](https://community.homey.app/u/ChrisBoer)\
**Post date:** [November 22, 2026, 9:45am UTC](https://community.homey.app/t/app-pro-climawise-smart-heating-cooling-room-by-room-heat-pumps-radiators-towel-dryers/162417/7 "2026-11-22T09:45:21Z")
</div>
You can easily do this with advanced flows you don’t need an app for that, but for people who don’t know how this works this app will be a warm welcome.
**Post date:** [November 23, 2026, 8:13am UTC](https://community.homey.app/t/app-pro-climawise-smart-heating-cooling-room-by-room-heat-pumps-radiators-towel-dryers/162417/8 "2026-11-23T08:13:21Z")
</div>
You need to go to the “Room” tab and add a device. You should be able to find it there, or you can try pressing the “Show sockets and relays” button. If you’re still having trouble, please send me a screenshot.
**Post date:** [November 23, 2026, 8:14am UTC](https://community.homey.app/t/app-pro-climawise-smart-heating-cooling-room-by-room-heat-pumps-radiators-towel-dryers/162417/9 "2026-11-23T08:14:24Z")
</div>
> [@ChrisBoer](#):
Indeed, everything can be achieved using advanced automation features, but the interface is simpler and allows for a greater number of conditions to be taken into account.
