# \[APP\]\[Pro\] BYD Vehicle – your BYD electric car in Homey
**URL:** <https://community.homey.app/t/app-pro-byd-vehicle-your-byd-electric-car-in-homey/161114>\
**Category:** Apps\
**Created:** [October 20, 2026, 3:25pm UTC](https://community.homey.app/t/app-pro-byd-vehicle-your-byd-electric-car-in-homey/161114 "2026-10-20T15:25:15Z")\
**Posts on this page:** 2\
**Page:** 1
<div class="post-metadata">
**Author:** ![Tomas\_Severa](https://sea1.discourse-cdn.com/flex025/user_avatar/community.homey.app/tomas_severa/32/33929_2.png) [@Tomas\_Severa](https://community.homey.app/u/Tomas_Severa)\
**Post date:** [October 20, 2026, 3:25pm UTC](https://community.homey.app/t/app-pro-byd-vehicle-your-byd-electric-car-in-homey/161114/1 "2026-10-20T15:25:15Z")
</div>
Hi everyone,
I own a BYD Sealion 7 and there was no BYD app for Homey yet, so I built one. It connects to the BYD cloud (the same service the official BYD app uses) and brings your car into Homey and your Flows.
\*\*BYD Vehicle\*\* – your BYD electric car in Homey [BYD Vehicle | Homey](https://homey.app/a/cz.severa.byd/) See the battery level, range and charging state of your BYD in Homey and use them in Flows: start or stop charging when there is solar surplus, get a notification when the battery drops below a level, or pre-heat the car before you leave. You can also lock and unlock the car, start the climate, flash the lights, find the car and close the windows. Tested on a BYD Sealion 7 (EU). Other BYD models that work with the BYD app should work too – feedback is very welcome! Note: the app uses BYD’s unofficial cloud API. Tip: share your car with a second BYD account in the BYD app and use that one in Homey, so your phone app stays logged in.
### What it does
**Status:** battery %, range, charging state, time to full, battery power, locked, doors/trunk open, windows open, interior temperature, tire pressures, location, “at home”, car awake/asleep, odometer. A **Refresh now** button on the device tile.
**Flow triggers:** battery dropped below / rose above X %, charging started / stopped, cable plugged in / unplugged, car arrived home / left home, location changed.
**Flow conditions:** battery above/below X %, is charging, cable plugged in, car at home, car awake.
**Flow actions:** lock / unlock, start climate (temperature + duration), stop climate, flash lights, find car (horn + lights), close windows, refresh status, start / stop charging (experimental).
### Before you start
1. **Use a second BYD account.** BYD allows only one active login per account, so Homey would log you out of the BYD app on your phone. In the BYD app, share the car with a second account and use that one in Homey.
2. **Set a control PIN** in the BYD app (Settings \> Security) for that account. It is needed for lock/unlock, climate, lights and windows. Careful: several wrong PIN attempts block remote control for the rest of the day.
3. Add the device: Devices \> + \> BYD Vehicle (unofficial), sign in, choose your country.
### Tested cars
- BYD Sealion 7 (EU) – tested by me
Other models (Atto 3, Dolphin, Seal, Seal U, Han, Tang …) use the same BYD cloud and should work, but I can’t test them. **Please let me know how it works with your car!** Hybrids (DM-i) show the electric range only.
### Good to know
- Every status update can wake the car, which uses some energy. The default interval is 10 minutes (5 minutes while charging), you can change it in the device settings.
- Start/stop charging is experimental and may not work in every region.
### Reporting problems
If a value looks wrong, open the device settings, scroll down to **Diagnostics** and post the “Last raw charging data” line here, together with your car model and country. That helps me a lot.
### Credits
This app builds on the great reverse-engineering work of **pyBYD / hass-byd-vehicle** by Joel Kåberg and **ioBroker.byd** by TA2k. Thank you!
This is an unofficial app and is not affiliated with BYD.
Tomáš
**Author:** ![Hans\_Eisink](https://sea1.discourse-cdn.com/flex025/user_avatar/community.homey.app/hans_eisink/32/12916_2.png) [@Hans\_Eisink](https://community.homey.app/u/Hans_Eisink)\
**Post date:** [October 22, 2026, 5:49pm UTC](https://community.homey.app/t/app-pro-byd-vehicle-your-byd-electric-car-in-homey/161114/2 "2026-10-22T17:49:40Z")
</div>
Great app! I own a Sealion 7 and have been hoping for an app for my Homey. Thank you so much—I’m going to start building my first flows! Thanks again!
