# \[APP\]\[Pro\] Advanced Triggers - Trigger and action cards with eventname for Advanced Flows
**URL:** <https://community.homey.app/t/app-pro-advanced-triggers-trigger-and-action-cards-with-eventname-for-advanced-flows/65651>\
**Category:** Apps\
**Tags:** app, tools, flow, homey-pro, advancedflow\
**Created:** [July 7, 2022, 10:27am UTC](https://community.homey.app/t/app-pro-advanced-triggers-trigger-and-action-cards-with-eventname-for-advanced-flows/65651 "2022-07-07T10:27:54Z")\
**Showing post:** 128
**Post date:** [November 18, 2022, 9:18am UTC](https://community.homey.app/t/app-pro-advanced-triggers-trigger-and-action-cards-with-eventname-for-advanced-flows/65651/128 "2022-11-18T09:18:19Z")
> [@dooniem](#):
> Is that possible in todays version?
No, i don’t see that posibility right now in AT.
Technicly it could be made, but placing variables in the Trigger, i am not sure that thats a very good idea, performance wise. I might look into it (some day/right now a bit).
But first let’s see if i have a better solution for you: The default Homey Alarms.
Perhaps it’s best you create 1 or 3 Alarms for this.
This gives you some excellent management options through the Homey app.
And, the only thing missing is a flow to set the times, but here is a HS i created for it yesterday 😉
```auto
let alarms = await Homey.alarms.getAlarms();
let alarm = _.find(alarms, a=>a.name=='AlarmName');
await Homey.alarms.updateAlarm({id:alarm.id, alarm: {time:'20:19'}});
[QlusterIT / nl.qluster-it.Chronograph / issues / #4 - Set a clock time and trigger on the set time — Bitbucket](https://bitbucket.org/QlusterIT/nl.qluster-it.chronograph/issues/4/set-a-clock-time-and-trigger-on-the-set)
The script is only needed to update times, enabling/disabling alarms can be done through normal flow cards.
Does this fit your need?
_[View the full topic](https://community.homey.app/t/app-pro-advanced-triggers-trigger-and-action-cards-with-eventname-for-advanced-flows/65651)._
