Homey Community Forum
[APP] NetAtmo by Athom
Version 4.0.6 released.
Now I have:
Error: token refresh failed, an additional error with an different try:
Error: Application usage reached (Code 403)
Yesterday I always got the “Token refresh failed” error
Today with 4.0.6 i get the “Application usage reached (Code 403)” error
Yeap, me too.
Netatmo is really giving them a hard time as it seems. :smiley: :smiley:
Now it worked
First also An error. After uninstalling app and reinstall it works
Yep, I can confirm that deleting the devices and the app and then reinstalling app and devices will work. During install of devices you need to reauthorise homey to access your netatmo data.
Thanks for the fix!
Working here as well :grinning: thanks
Is working here also, thanks!
Hi am i doing something wrong i want to let homey say Hello with the persons name when its recognized. Just got my homey and it’s all a bit new.
Sorry had to place in two posts
Netatmo definitely looks fixed. If only we could put temperature reading on tile itself without the need to long press the tile. :-/
What did you do to get it to work? I receive the same fault message and have now reinstalled the app three times (plus rebooting Homey)
Regards /Niklas
Strange. I did just that, I’ve deleted Netatmo devices, uninstalled the app, reinstalled the app and went trough re-authorization process (added again device, authenticated to netatmo, approved homey app).
Now it worked for me as well but I can’t say why - I just kept trying, waited about 5 min and then tried again. Now it worked without a fault message. hmm
Can you get a notification in a flow to work? Nothing happens in my “Human detected -> send a mobile message” Flow (but works via Netatmo app)
hi
I’m getting an error “cannot convert undefined or null to object” after authorising Athom to manage my netatmo devices.
I’m not able to add my device.
I’ve tried to relaunch the app, and to reinstall it as well…
any help.?
thanks
Any one who have a clue why I get insights on all my weather station devices (outdoor, rain, wind, extra indoor) but NOT from the main station itself? (It is reporting - I can see that from my NetAtmo webpage/app)
Edit: Restarting NetAtmo app did not do the trick. Removing and re-adding the device did, though.
Solved (for this time at least)
any updates in when netatmo valves might be supported (controlling temperature settings). Or is the way forward to post it as an issue since it is listed under “supported devices”. Sounds like no one has managed to get them to work properly…
Without reporting an issue it will never be resolved… Athom does not track this forum, so definitely report an issue.
Just did, thank you :blush:
You mean the valves that are already in the app?
