Homey Community Forum
App Life360
Yes, please continue. Use the app for homey and other information :ok_hand:
I have done a complete rewrite of the App life360. It might be still buggy as everything is changed. The app is now written for SDK 3 and a completely new API towards cloud life 360.
If you want to test this you can do this from Connect Life360 | Homey
But be aware that this app can be buggy, so do not use it if you depend on it!
Great work, thx @MarcelT! I use this app daily and am very happy with it!
(shouln’t the topic title be changed, now that this thread turns into the “official” apps discussion thread?)
Thanks Marcel!
Only way to find out is to use it, right? :slight_smile:
I’ll let you know if this works, if it doesn’t I’ll fall back to my ancient 1.2.2 that never let me down :+1:t2:
There is a new test version with advanced settings that give information about the App360 life on the phone. Can be handy for issue tracking.
Thanks! Changed topic :slight_smile:
Hi, I haven’t reacted to this because I was unsure if I stopped working on this app. But in the meantime, I have a new version of the test app. The main prio is stability and if this is working well I might add new functionalities.
Please try the new test app.
I have not much experience in it yet. And If i publish something which I cannot test myself at all feels kind of asking of problems :slight_smile:
Something for the future perhaps…?
Thanks Marcel, I will also test it. Great job!
@MarcelT
Ten eerste top om zo de app te kunnen koppelen echter loop wel tegen aan ( beta versie ) dat ik hem op 1 min verversen zet en dit zowel met de oude als nieuwe app niet update tenminste te laat.
Laatst gezien
2021-11-27 14:11:19
4 minuten geleden
Laatst gezien
2021-11-27 14:12:48
4 minuten geleden
2 telefoons de ene is android de ander ios als ik de logging mag geloven logt deze wel elke minuut… is hier een verklaring voor ?
Ik denk dat er verwarring is over die tijden. 1 van de opties erboven is in die tijd veranderd. Sommige van de opties erboven zijn soms uren geleden begonnen met status veranderen. Bijvoorbeeld laden/ontladen. Kan uren zijn. Hij update wel, want als je op de batterij onderin klikt zie je de juiste info over hoe vol je telefoon batterij is.
If you could please keep the conversation in English as much as possible, then more people will be able to participate and help you. If you would rather not or can’t communicate in English then please check out Non-English boards/categories:
https://community.homey.app/c/non-english
Or here:
Nederlands (Dutch)
You’re right. When I read the Dutch post I assumed it was in the Dutch area. We’ll continue in English. Thanks for reminding.
This time is the last time that the api have seen the life360 app on your phone. I will add a last sync time in the settings.
Hi All,
Again a bug fix version, in the new SDK the timezone was not working correctly so all dates were in UTC Time. This is fixed and now times are converted to local time. Additionally, I have added in Advanced Setting a group where you can see the latest sync time and also a counter. This counter will be reset by restarting homey or app.
Beste
Ik heb 3 flows en allemaal lijken niks te doen met de locatie als iemand thuis is
Ik kom thuis en mijn vriendin zou weg moeten zijn dan mag de radio aan , nu kom ik net thuis en de radio gaat aan en mijn vriendin is gewoon thuis
Wanneer mijn vriendin weg gaat en ik weg ben moet de stofzuiger aan gaan , ook nu als ik thuis ben gaat de flow gewoon door
Wanneer ik weg ga en mijn vriendin ook weg is moet de stofzuiger aangaan echter wanneer mijn vriendin als nog thuis is gaat de flow ook gewoon verder.
Of ik zie het verkeerd maar als ik onder het kopje EN de kaart omkeer , beide gevallen gaat de flow gewoon door… kan iemand mij helpen of is dit een bug in de 360 app
Or here:
Nederlands (Dutch),
some one ?
