I hope to have fixed the start/stop playing
trigger card once and for all. Could you check again. I have also removed one of the duplicate condition cards for is (not) playing
. That might break some flows for some people but cleans up the code and the flows can be fixed easily. Could you test again.
Start still doesn’t work. Maybe just change stop trigger in start/stop trigger. People can then ad an condition card in the And section with is or is not playing. Problem solved!
I cant as these triggercard are built in based on the speaker_playing
capability (and I dont want too, I want to get it right). So help me out here. The only thing I can do it to determine when I need to set the speaker_playing
capability to true or false. The code looks like this:
// capability speaker_playing
if (result.state !== "pause" && !this.getCapabilityValue('speaker_playing')) {
this.setCapabilityValue('speaker_playing', true);
} else if (result.state == "pause" && this.getCapabilityValue('speaker_playing')) {
this.setCapabilityValue('speaker_playing', false);
In human language this says "if the device state (result.state
) is not pause and the state of the device in Homey is not playing then set it the speaker_playing
capability to playing or if the device state is pause and the state of the device in Homey is set to playing then set it to not playing. My guess is that there are cases where the state of the device is not changed from pause while it’s actually playing something (like radio) and thus it wont change the capability and therefor not trigger the start playing trigger card. I need to find out if this is the case. Could you check this through http://ipbluesound :port/Status and see what the result is when starting and stopping your music.
And thanx for the beers, much appreciated with this heat …
Your welcome!
Hhm. I do understand you. But even when i cut off the power and restart the Powernode and start play some music, Start playing is not triggered.
You will need to access this URL (replacing the IP and port of your Bluesound device) to see what the status is. I use this output to update the device instance in Homey.
http://ipbluesound:port/Status
Give it another try asap!
OK, let me know if I’m not making any sense, but I’ll try to contribute to this (with my limited knowledge). I looked at the URL and found the following states (for my Node 2i):
Playing Tidal / Spotify state=stream
Playing from NAS state=play
Playing optical input state=stream
Paused state=pause
playlist ended state=stop
Hope this helps, and again thanks for your efforts, also to Peter
Addition:
Playing TuneIn (radio) state=stream
Playing Bluetooth state=stream
Bluetooth or optical selected but no signal, state=connecting
I noticed that Bluesound now have an official API documentation on their website:
Still weird that there is no option to switch source to any specific i would like, in my case to optical 2 for example when my tv is turned on.
v3.0.4 - 202x-xx-xx
- Updated to SDK3 (require Homey firmware 5.x)
- Fixed an issue with the start/stop playing trigger card
- Removed a duplicate “is (not) playing” condition card. You might have to update your flows because of this.
This release is available in the test channel in the app store. You can only install this if you are running Homey firmware 5.x which is still in experimental phase.
v3.0.5 - 2021-02-22
Hi! I’m new to homey, I hope this is the right place to ask a question about the flows of the blusound app?
How do I trigger a specific playlist or song to be played? I only manage to play the song that is currently playing?
I use the app in my flows to start a certain programmed PRESET: Spotify or radio channel. Not sure if you can actually select a certain playlist. Continue in the current playlist/song should be possible?
Also use the presets for this
But you can only start the service, not choose artist or song och playlist? Thanks for getting back to me!
You can ad a playlist to your preset first
Awesome, I think I’m starting to get how it works. But in “then” when I choose preset, how do I choose theta preset, the Is grayed out and I can’t save it… thanks for your replies!
Thanks!! Got it!
