# Alexa/Homey skill not discovering new Hue light – existing devices still work
**URL:** https://community.homey.app/t/alexa-homey-skill-not-discovering-new-hue-light-existing-devices-still-work/158718
**Created:** [August 24, 2026, 8:35pm UTC](https://community.homey.app/t/alexa-homey-skill-not-discovering-new-hue-light-existing-devices-still-work/158718 "2026-08-24T20:35:12Z")
**Posts on this page:** 1
**Showing post:** 14
### Author: ![hyeung](https://sea1.discourse-cdn.com/flex025/user_avatar/community.homey.app/hyeung/32/41223_2.png) [@hyeung](https://community.homey.app/u/hyeung)
#### Post date: [September 2, 2026, 1:47pm UTC](https://community.homey.app/t/alexa-homey-skill-not-discovering-new-hue-light-existing-devices-still-work/158718/14 "2026-09-02T13:47:00Z")
## Update: similar Alexa discovery reports across multiple Homey models and years
While investigating this further, I have found several earlier community reports describing similar problems with Alexa failing to receive newly added Homey devices.
### October 2023 – Homey Pro Early 2023
A Homey Pro 2023 user reported that Alexa initially imported their Homey devices correctly, but devices added afterwards were not published automatically. Disabling and re-enabling the skill temporarily restored the missing devices, but the problem subsequently returned:
> [@Homey does not add the new devices to Alexa](https://community.homey.app/t/homey-does-not-add-the-new-devices-to-alexa/90750):
> I have a Homey Pro 2023, which I connected to Alexa with its skill. When I activated the skill Alexa correctly recognized all the devices already in Homey. But, in the following days, I noticed that the new devices I added later to Homey were not automatically connected to Alexa. So I tried disabling the Homey skill on the Alexa app and then re-enabling it again. This way Alexa correctly recognized all devices, even the new ones it had not added before. Now, however, I added more devices and …
The same thread also contains a report from a **Homey Pro 2019** user in April 2024. Their new devices sometimes took between 24 and 48 hours to appear, while another discovery attempt took more than three days.
### March–May 2025 – Homey Pro Early 2019
In March and April 2025, @RogoGames reported that new devices were no longer being recognised by Alexa. Old Alexa scenes continued working, but new devices and scenes were ignored despite restarting Homey, restarting the Alexa skill and repeatedly running discovery:
> [@Alexa not recognizing new devices, issues with flows and Moods](https://community.homey.app/t/alexa-not-recognizing-new-devices-issues-with-flows-and-moods/133124):
> Hey everyone, I’m having some major issues with my Homey Alexa integration and wanted to see if anyone else is dealing with the same problems. New devices aren’t being recognized or added to Alexa anymore. Favorite flows aren’t showing up as scenes in Alexa, despite trying everything from restarting the Homey skill to rebooting Homey and creating new regular and advanced flows. Old scenes still work fine, but new ones are completely ignored. Moods still aren’t working with Alexa voice command…
In a later post, the same user confirmed that they were using a **Homey Pro 2019** and that the issue remained unresolved after being reported to Athom:
> [@Alexa Issue and My Transition from Homey to Home Assistant: What I Learned](https://community.homey.app/t/alexa-issue-and-my-transition-from-homey-to-home-assistant-what-i-learned/136235):
> Hello everyone, I’m writing this post to share my experience, in the hope that it may be helpful to other users or even to the developers of Homey. This is an honest testimony, born from years of use, many attempts to fix things, and, ultimately, an inevitable choice. 1. Problems with Technical Support and the Lack of Assistance The most serious problem isn’t even technical, but human: after reporting a critical bug (Alexa could no longer discover new devices from Homey), I was completely ign…
### Current reproductions
The current failure has now been reproduced independently on:
- My Homey Pro Early 2019
- @smarthomesven’s Homey Pro Early 2019
In both cases, existing Homey devices remain operational through Alexa, but newly created supported devices—including a native Homey Virtual Switch classified as a light—are not discovered.
These historical reports do not necessarily prove that every case has the same technical cause. However, they show that similar Homey–Alexa publication failures have been reported intermittently **from at least October 2023 onwards** , affecting both Early 2019 and Early 2023 units.
Athom Support has now escalated my case to engineering. To help establish the current scope, I would be grateful for comparison results from anyone who already uses the **official Homey Alexa skill** , particularly users of Homey Pro Early 2023 or Early 2026.
The quick test is:
1. Create a temporary native Homey **Virtual Switch**.
2. Set **“What’s plugged in?”** to **Light**.
3. On supported newer models, ensure it is not selected under **Amazon Alexa → Excluded Devices**.
4. Run **Discover Devices** in Alexa.
5. Check whether the virtual light appears.
There is no need to disable or relink the Homey skill or change any existing Alexa devices.
Please report:
- **Homey model:**
- **Homey OS version:**
- **Alexa country/region:**
- **Existing Homey devices working through Alexa:** Yes/No
- **New virtual light discovered:** Yes/No
Successful results are just as valuable as failed ones. I will summarise the findings and pass them to Athom as part of the current engineering investigation.
_[View the full topic](https://community.homey.app/t/alexa-homey-skill-not-discovering-new-hue-light-existing-devices-still-work/158718)._
