# Advanced Flow Working in Test State But Failing Once Saved
**URL:** <https://community.homey.app/t/advanced-flow-working-in-test-state-but-failing-once-saved/111164>\
**Tags:** flow, homey-pro, advancedflow\
**Created:** [June 7, 2024, 7:13pm UTC](https://community.homey.app/t/advanced-flow-working-in-test-state-but-failing-once-saved/111164 "2024-06-07T19:13:03Z")\
**Showing post:** 10
**Post date:** [June 7, 2024, 8:25pm UTC](https://community.homey.app/t/advanced-flow-working-in-test-state-but-failing-once-saved/111164/10 "2024-06-07T20:25:46Z")
> [@Ruckus](#):
> So when turned off → dim to % → then turn off
That’s not what I meant, and _ **it causes a loop** _
When turned off → dim to % (this causes most lights to turn on with dimlevel %) → Then turn off
Now the flow starts again immediately, because:
Now the flow starts again immediately, because …
And so on and on.
I even showed it in the other topic, you added the trigger somehow 🤷‍♂️😉
> [@\[APP\] Zooz - Let's build smarter tech together](https://community.homey.app/t/app-zooz-lets-build-smarter-tech-together/130214/36):
> you should always turn it off like this:
> Then…
> -dim light X to 1%
> -turn light X off after 1s
I did not say to trigger the flow with ‘When light X is turned off’
I meant, or tried to explain, in all the flows where you use the action card “Then turn light X off” you should use
Then…
-dim light X to 1%
instead.
Now the light should have dimlevel 1% when you turn it on from anywhere.
I hope it’s a bit clearer now
_[View the full topic](https://community.homey.app/t/advanced-flow-working-in-test-state-but-failing-once-saved/111164)._
