# Advanced Flow - how to make Saves Permanent?
**URL:** <https://community.homey.app/t/advanced-flow-how-to-make-saves-permanent/67688>\
**Category:** Flows\
**Tags:** advancedflow\
**Created:** [August 21, 2022, 11:29am UTC](https://community.homey.app/t/advanced-flow-how-to-make-saves-permanent/67688 "2022-08-21T11:29:28Z")\
**Showing post:** 5
**Post date:** [August 21, 2022, 2:11pm UTC](https://community.homey.app/t/advanced-flow-how-to-make-saves-permanent/67688/5 "2022-08-21T14:11:25Z")
> [@Busta999](#):
> Homey is constantly dropping offline.
Ah, seems like a “too modern wifi setup for Homey” issue.
Try this:
> [@Problems connecting your new Homey Pro to your WiFi? Try this!](https://community.homey.app/t/problems-connecting-your-new-homey-pro-to-your-wifi-try-this/10161):
> Make sure your WiFi is using the 2.4 GHz network. Make sure your WiFi uses the b / g standard, only n or ac does not work. Turn off your Homey. Restart your Router and any Access Points that distribute IP addresses. Start your Homey again. If the above do not work, turn off 5 GHz WiFi and support for n and ac in your Router / Access Point during Homey installation. Ensure that your SSID (the name of your WiFi) does not use characters other than numbers and letters - do not us…
_[View the full topic](https://community.homey.app/t/advanced-flow-how-to-make-saves-permanent/67688)._
